Activity Forums Adobe After Effects Please help…
  • Please help…
    Posted by Sando Calrissian on March 14, 2006 at 9:30 am
    I got in this morning to find that my overnight render had failed after 9 hrs. The log displayed
    ‘After Effects error: adding to movie (-1309). (44
    Al replied 20 years, 6 months ago 3 Members · 2 Replies
  • Ron Lindeboom
    March 14, 2006 at 11:15 am
    To avoid these issues in the future, make your critical renders into exporting numerical sequence renders instead of exporting a movie. This way, if it crashes, you have every frame right up to the one where it crashed. Not only will it give you the security of knowing your work is there but you will also have an audit trail to follow to isolate where the issue occurs that is causing your problem.
    Best regards,
    Ron Lindeboom
  • Al
    March 14, 2006 at 3:50 pm
    second that. targa sequence all the way…
