Activity › Forums › Panasonic Cameras › Please Help, Really Wierd Thing Happening
Posted by Spencer Davis on January 26, 2008 at 11:33 pmWhen I try putting my hvx200 into VCR mode, it won’t, even though I hold down the button for a while. Then, when I try to turn it off, the hvx wont and i have to manually unplug the battery. Does anyone have any ideas? Thanks for the help
Jan Crittenden livingston replied 18 years, 7 months ago 4 Members · 5 Replies -
Emre Tufekci s.o.a.
January 27, 2008 at 12:35 amSounds like a firmware issue. Try updating ot re-installing the firmware. If it does not work send it to panasonic.
Were you able to put it into VCR and PC mode before?
Emre
http://www.productionpit.com
Boxx Tech PC, dual-dual AMD 2.0,4BG ram,Avidexpress HD w/Mojo,UVW-1800,DSR-25, Adobe Premium CS3.Gspeed ES.Steadicam OP/Owner.“Creative cow is udder madness.”
Rennie Klymyk
January 27, 2008 at 2:18 amHave you tried the reset button? Page 126 of the manual.
“everything is broken” ……1st. coined by Esther Philips I believe.
Spencer Davis
January 27, 2008 at 4:45 pmI can’t even do a firmware update since like the vcr button doesn’t work, neither does the menu button. Just before this happened, I was uploading film to my computer, like I always do, and I was able to make the camera go into vcr mode. After uploading two of the clips, the camera screen said micon error, and the froze the uploading process. I had to force quit FCP and i ejected the camera. Then when i tried turning off the camera, it wouldn’t, and when i tried putting the camera into vcr mode, it wouldn’t. If I put the camera into tape mode, everything does work fine. I don’t know if any of this helps…
Spencer Davis
January 27, 2008 at 4:49 pmReset button works, but the problem continues after the hvx has been reset
January 28, 2008 at 12:50 amYou should contact Panasonic Service and have them look at it. http://www.panasonic.com/broadcast and click through the support section to service on your model and zip code. Something is obviously wrong.
Best,
Jan
Jan Crittenden Livingston
Product Manager, HPX500, HVX200, DVX100
Panasonic Broadcast & TV Systems
