Activity Forums VEGAS Pro Please help – playback locked – EEK!
  • Please help – playback locked – EEK!
    Posted by Story Catcher on June 1, 2005 at 5:10 pm
    Hello Vegas Users
    I am in the middle of editing a video when for some reason my playback locked. I tried shutting down and restarting but it won’t lock. I thought it had something to do with that pesky loop feature that might be set on such a small place but I can’t see that. Even when I press the ‘play from start’ button it just won’t move.
    When I place the cursor on the timeline it isn’t the usualy white line – it does look like a very thin grey line (makes me think this is a loop problem)?
    Anyone have any ideas? I’m short for time and would so greatly appreciate any help anyone can offer.
    Many thanks
    Heidi
    p.s. I am using vegas 4.0 if that matters.
    Liam Kennedy replied 21 years, 2 months ago 2 Members · 5 Replies
  • Story Catcher
    June 1, 2005 at 5:28 pm
    To further explain.
    It seems that it will play for 2 frames then stop. It doesn’t matter where on the timeline I click to play from it will only play for two frames.
    I tried cutting and pasting the video into a new vegas project and the same thing happened.
    I also tried deleting each track one by one to see if it was something set with a track, but I still had the same problem.
    Any help would be very much appreciated.
    Heidi
    p.s. I am almost done this video after days of editing – just this morning I was thinking I should be saving a back up file (which I usually do). I can’t believe I was that daft not to. rrrgggg.
  • Story Catcher
    June 1, 2005 at 6:03 pm
    Well, just thought I’d add to this post in case anyone does a search due to this same problem.
    I have no clue why or how but the project would only play 2 frames at a time, anywhere on the timeline.
    After 2 hours of fretting and testing, closing and re-opening vegas and files. I decided to turn off the computer. When I turned it back on everything was fine.
    ? go figure.
    Just thought I would add to the post in case anyone was researching an answer or if this happens to anyone else.
    Thanks – happy editing all.
    H
  • Liam Kennedy
    June 1, 2005 at 11:56 pm
    Sounds a bit like the “sync cursor with RAM preview issue”…. but I don’t think that problem happened unless you were trying to do a ram preview. The issue is whenever you have the sync cursor enabled (in V5 definitely) and you tried to select a loop and then do a RAM preview it would only ever display 2 frames of the selected loop (sound familiar?). The solution was to turn off Sync Cursor and then do your RAM preview. This seems to be fixed in V6b.
  • Story Catcher
    June 2, 2005 at 8:40 pm
    Thanks Liam
    You’re always so knowledgable about Vegas.
    Hopefully one day I’ll be able to help out more on the forum, instead of always asking the questions.
    Cheers
    Heidi
    http://www.thestorycatcher.ca
  • Liam Kennedy
    June 4, 2005 at 6:56 am
    Glad I could help. I’m just “paying it forward”. 99.99% of what I post is simply something I learned from someone else anyway.
