Activity › Forums › Adobe Encore DVD › PLEASE HELP ON TRANSCODING HANG
  • PLEASE HELP ON TRANSCODING HANG
    Posted by Carlos on September 16, 2007 at 4:06 pm
    Hi, I need to burn this project. I finished, tested it, and works fine. However I can
    Jeff Bellune replied 19 years ago 3 Members · 3 Replies
  • Vincent Rosati
    September 16, 2007 at 9:27 pm
    Can you encode your assets with your editing app. If you get a chance, fill out your profile with your hardware/software versions.
    I never allow Encore to transcode, but you have to encode into a format that Encore will accept. Trial & error, than save or note your presets.
    I always encode out of Premiere with MainConcept MPEG Pro, than test the validity of the MPEG in Endore with a “dummy” project. Than, when I go to build the actual DVD it takes only a few minutes, even for a full length DVD.
    Also, check to make sure the lengths of your Audio and Video tracks are the same, in your timelines.
  • Vincent Rosati
    September 16, 2007 at 9:53 pm
    I just noticed you’re using AE.
    Create an Output Module Preset: Format: MPEG2-DVD, Quality: 5.0, VBR 4/6/8 Mbps, PCM audio, Multiplex: DVD. Save the preset, than render out your MPEG.
    When you bring the resulting MPEG into Encore you should be blessed with a Transcode Status of “Don’t Transcode”. 🙂
    Of course you can use even higher bitrates, and in my version of AE I can only do a 1-pass encoding, MainConcept in Premiere allows 2-pass.
  • Jeff Bellune
    September 17, 2007 at 9:40 pm
