Activity › Forums › Adobe After Effects › Please Help! Need help understanding 16:9 FHA
Posted by Kenny Frankland on September 10, 2008 at 2:39 pmHello
I’ve just completed a animated music video and the client requires it to be PAL 16:9FHA for TV broadcast (UK)
I’ve tried reading up about it but can’t find any info based on HD.
The video I have was rendered out of After Effects CS3 at these settings:
Preset: HDV/HDTV 720 25
1280×720 (locked at 16:9)
Aspect Ratio: Square pixels
Is this correct???
Should my aspect ratio be D1/DV Pal widescreen?
Thankyou for your time
Kenny
Conrad Olson replied 18 years ago 4 Members · 8 Replies -
Kenny Frankland
September 10, 2008 at 3:19 pmAfter further reading elsewhere I have another question…
Is 16:9 FHA only relevent to standard broadcast formats but tv stations that broadcast in HD would use 1280×720 square ratio like my original export?
I’m so confused!
Kenny Frankland
September 10, 2008 at 9:55 pmThanks Dave
I also tried google for some time before posting here with no luck.
I’m bottom of a pile at the moment so I don’t have direct contact with the actual broadcaster. I’m dealing directly with the record label, who is dealing with a ‘TV Plugger’ who is dealing with a company that takes care of this sort of thing, who are dealing with MTV. It’s quite frustrating that nobody knows. The label has asked this company for advice, but so far no response.
Kenny
Chris Wright
September 10, 2008 at 9:56 pmPAL HDTV
HDTV 720/30p Frame size: 1280 x 720
Frame aspect ratio: 16:9
Pixel aspect ratio: 1
Frame rate: 30 fps
Field order: upper field first -
Chris Wright
September 10, 2008 at 11:14 pm720p
16:9 1:1 Used for 750-line video with raster artifact/overscan compensation, as defined in SMPTE 296M.
(PAL, SECAM DTV progressive material) not interlaced.)The European Broadcasting Union (EBU) recommends that its members use 720p50 with the possibility of 1080i50 on a programme-by-programme basis and 1080p50 as a future option.
I don’t think there’s a standard in Europe yet, lol.
Conrad Olson
September 12, 2008 at 1:33 pmIf you have been asked to deliver a 16:9 FHA version your client is probably expecting a standard definition delivery, not an HD delivery. FHA (Full Height Anamorphic) is the term used to describe the squeeze applied to 16:9 footage to fit it into the 4:3 standard definition frame. Becasue HD is 16:9 natively there is no need for FHA in HD.
If you have produced your whole After Effects project in 16:9 HD the easiest way to convert it into PAL 16:9 FHA is to create a new composition using the PAL D1/DV Widescreen preset, then drag your HD comp (or render) into the new sequence and scale it down to fit the comp (or used the fit to comp command). If the interpertation of your HD stuff is correct then is should look fine in the SD comp.
You should be able to render a progressive piece out without having to switch on the field order. SD PAL can deal with progressive clips, it basically splits the progressive image over both fields.
I don’t think there are any HD music channels in the UK yet.
Kenny Frankland
September 12, 2008 at 1:44 pmThanks Conrad
That’s just the information I needed.
Cheers
