Activity Forums Apple Final Cut Pro Legacy Please help – mpeg streamclip files appear unrendred in FCP
  • Please help – mpeg streamclip files appear unrendred in FCP
    Posted by Andy Levine on March 2, 2006 at 3:25 pm
    when I open a file in FCP that was conveterd from DVD through MPEG streamclip It appears unrendered… I am I messing up the file settings? What is standard FCP quicktime file format? What about sound settings?
    Andy Levine replied 20 years, 6 months ago 4 Members · 8 Replies
  • 8 Replies
  • Walter Biscardi
    March 2, 2006 at 3:27 pm
    Your project settings don’t match your clip settings.
    Walter Biscardi, Jr.
    Director, “The Rough Cut”
    https://www.theroughcutmovie.com
    Now Posting “Good Eats” in HD for the Food Network
  • Andy Levine
    March 2, 2006 at 3:46 pm
    walter, thanks.
    my fcp system is set to DVNTSC 48KHz (standard/easy setup) mpeg streamclip doesn’t offer that exactly… they offer APPLEDVPRO-NTSC. Is there another setting on MPEG streamclp I should be using?
    -andy
  • Jeremy Garchow
    March 2, 2006 at 5:07 pm
    You have to make sure that your frame size is also correct (720×480) and that you have the correct field order/frame rate selected.
  • Andy Levine
    March 2, 2006 at 5:40 pm
    I’ll check frame size but what is the correct standard setting?
    APPLEDVPRO50-NTSC. Are those two equavalent?
    thanks
  • Jeremy Garchow
    March 2, 2006 at 5:53 pm
    Select dv not dv50.
  • Andy Levine
    March 2, 2006 at 5:56 pm
    frame size is correct… files are no longer rendered…hooray! BUT files are huge… 16 second clip is 81MB…that can’t be right.
    please help if you can.
    -andy
  • Bret Williams
    March 2, 2006 at 6:04 pm
    DV is approx 5 minutes per gig. You can do the math.
  • Andy Levine
    March 2, 2006 at 6:41 pm
    i understand 16sec = 81mb 1min = 304mb 5min = 1.52gb is that not high? Am i doing something wrong?
