Please help me implement my expression, stupid mistake somewhere
Hello, my expression is supposed to be placed at solid layer´ s opacity channel and solid has “advanced lightning” effect to it. Purpose of this expression is to procedurally turn opacity from 0 to 100 fast for random time interval (keep glowing) and after that turn fast to 0, wait random time with value 0, and then again raise up to 100 for few secs and then fade away again, so i have relatively realistic lightnings opacity, i dont care about anything else, i just couldnt use random twitching on this because lightning strikes need a small breaks in between to appear real. I am absolutely new to expressions and i teamed this up with senior java programmer, we both assumed at a time of writing that assigning global variable to a slider is as simple as “a=5; thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) = a;”, i dont know how to do any better. There are 3 variables that are meant to be global:
nextStartTime = 0;
curValue = 0;
isGrow = 0;so they are assigned to a slider and referenced to an expression, meanwhile they are also rewritten by expression. My implementation of expression looks like this:
stepFlash = 10; // Prirustek intezity blesku
bleskCekaOdSec = 1;
bleskCekaDoSec = 10;
bezBleskuCekaOdSec = 5;
bezBleskuCekaDoSec = 10;
if (time > thisComp.layer(“Null1”).effect(“nextStartTime”)(“Slider”)) {
if (thisComp.layer(“Null1”).effect(“isGrow”)(“Slider”) == 1) {
// Roste
if (thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) < 100) {
// Zvedam hodnotu
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) += stepFlash;
} else {
// 100 nebo více
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) = 100; // Nastavim maximalni hodnotu
// Interval pro delku cekani s rozsvicenym bleskem
seedRandom(1, false);
thisComp.layer(“Null1”).effect(“nextStartTime”)(“Slider”) += random(bleskCekaOdSec, bleskCekaDoSec);
// Oznacim pro pokles hodnoty
thisComp.layer(“Null1”).effect(“isGrow”)(“Slider”) = 0;
} else {
// Klesa
if (thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) > 0) {
// Snizuji hodnotu
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) -= stepFlash;
} else {
// 0 nebo mene
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”) = 0; // Nastavim minimalni hodnotu
// Interval pro delku cekani bez blesku
thisComp.layer(“Null1”).effect(“nextStartTime”)(“Slider”) += random(bezBleskuCekaOdSec, bezBleskuCekaDoSec);
// Oznacim pro rust hodnoty
thisComp.layer(“Null1”).effect(“isGrow”)(“Slider”) = 1;
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”)——
But there is raw expression we wrote yesterday:
// Global variables
nextStartTime = 0;
curValue = 0;
isGrow = 0;stepFlash = 10; // Prirustek intezity blesku
bleskCekaOdSec = 1;
bezBleskuCekaDoSec = 10;if (time > thisComp.layer(“Null1”).effect(“nextStartTime”)(“Slider”)) {
// Roste
// Zvedam hodnotu
} else {
// 100 nebo více
} else {
// Klesa
// Snizuji hodnotu
} else {
// 0 nebo mene
thisComp.layer(“Null1”).effect(“curValue”)(“Slider”);—–
Any help is going to be very much appreciated, thank you!
