Activity › Forums › AJA Video Systems › Please help – laying off to tape
  • Please help – laying off to tape
    Posted by Andrew Gilmore on June 29, 2005 at 3:41 pm
    I am going to do an Edit to Tape of a 100 minute project (1080 23.98 psf). This will be my master for color correction.
    I was told that there is a 1 frame offset when downconverting on playback. This is my first HD layoff. Am I correct to assume there is no offset (because there is no delay caused by scaling/frame rate conv.) ?
    Anything else I should be aware of?
    Should I enable the “abort capture on dropped frames” feature so I know if any frames are defective?
    Any suggestions and advice will be greatly appreciated.
    Thanks in advance.
    G5 dual 2.5
    Kona 2
    FCP 4.5
    10.3.9
    XServe RAID
    Andrew Gilmore replied 21 years, 3 months ago 1 Member · 0 Replies
  • 0 Replies
