Activity Forums Boris FX Particle Illusion Please help, how do I get 720×576 format output video?
  • Please help, how do I get 720×576 format output video?
    Posted by Anna Stefankova on April 16, 2007 at 2:34 pm
    Hi, I am new to pI3 so maybe this is easy thing, but I cannot get my video out of PI3 in 720×576 format. In Project Settings I changed Stage Size to the required size but in the fields next to it the ratio is 640 x 480 and even if I rewrite it and I save it, the next time it is back to the original values, not 720×576. When I go to Save Output than the resolution indicated, at 100%, is still only 484×414.Why? Could you please tell me what to do about this? I want to use the video in AE later on. Thanks a lot for help.
    Curious Turtle replied 19 years, 5 months ago 3 Members · 3 Replies
  • James Harris
    April 16, 2007 at 10:34 pm
    As PI uses the image on the screen to render the output then the image on your screen has to be the FULL size that you want to output. You should open the stage up as big as you can and select zoom to 100% and none of your image should be ‘missing’. Then you can render out full size.
    Because the resolution you are getting is an odd number it sounds just like the problem I had recently and so the answer above should work. If your screen resolution is too small you can use the stand alone renderer, which is in there somewhere.
    After this you will re-read the help file and find it was in there all along, just the same as I did!! (The Offset function in PI is still a PIG however!)
    James
  • Anna Stefankova
    April 17, 2007 at 11:59 am
    Thanks a lot. You were right in both cases = it works and I really found it later on in the manuals/tutorials 🙂
  • Curious Turtle
    April 19, 2007 at 8:48 am
    Just to add to the answer.
    If you want to do PAL resolution projects then set your project up to 768×576 and make sure you interpret the footage as square pixels in After Effects.
    This will make your animations look perfect when you put them into a PAL resolution AE composition.
    It’s a square (computer) v. non-square (video) pixel thing that we don’t need to get too detailed about here.
    Cheers,
    Ben
    Curious Turtle Professional Video
    Training | Editing |Support
    http://www.curiousturtle.com
