PLEASE HELP!! Errors in burn – & I can’t find the culprit
Hello all from the deep freeze here in Minnesota. This is my situation, and I’ll give as many details as I can and I’ll appreciate your suggestions, advice, anything. THANK YOU IN ADVANCE. This is my first post though I’ve read a number of them in the past. OK, these are the details. Powerbook G4 FCPHD as well as an imac g4 that I’ve also used for burning some discs. I have a firewire 800 external HD for media. In Final Cut Pro HD I’ve got a timeline with 1 hour 45 minutes of footage. All very straightforward w/ 2-4 tracks vid/audio. I’ve got a total of three timelines of approx. the same length (to be three DVD’s). I’m using iDVD 5.
I have yet to successfully burn the project 1 (first film). The 2nd and 3rd projects/timelines all burned successfully, without a hitch and are completed. All three of these were in the same open project. So this is what I’ve done with the first project. I exported out of FCP HD first as not self-contained, and then after all the encoding/burn (it was early morning and didn’t see it end) the message left on screen was ‘burn finished – some errors were found in burn process’. I then moved project to my imac g4 (self-contained movie) and used iDVD 5 and after the encoding… same exact error message. With a TOTALLY BLANK dvd-r. Doesn’t burn a thing. I talked to FCP support guy and then watched the exported film in Quicktime and it was not smooth, it was catching frames though audio seemed fine. I trashed my pref’s and re-exported and the film ‘appeared’ fine — from simply viewing it in QT. But I’m no expert – –
So I tried to burn again — and after it all, same message. ‘burn finished – some errors were found in burn process’.
WHAT DO I DO NOW? I just don’t know what to even consider. I’m basically a semi-new user, having only done a few projects in FCP — so your advice will be very much appreciated!!!
I wondered if there were dropped frames or something like that in there, how would I find it?? Please help!
THANK YOU very much!
