Activity Forums Avid Media Composer PLEASE HELP – DVD Chapter Problem
  • PLEASE HELP – DVD Chapter Problem
    Posted by Vivian Cruz-o’doherty on March 28, 2007 at 3:06 am
    I’ve tried unsucessfully to make an DVD with chapter points from Avid Media Composer Adrenaline. I was told to
    1)Export the sequence as a Quicktime Reference.
    2)Close the MC app then open Avid DVD by Sonic.
    3)Add the movie(s).
    4)Choose the aspect ratio.
    5)Save the project.
    6)Burn the DVD.
    I did that but I have four sequences that need chapter points on the DVD, so added the four sequences and followed the rest of the steps. THE PROBLEM: The video in second of the four sequences freezes 10 seconds before the end but all other segments are fine (audio is fine too). I checked and re-checked my sequences – no problem there. I even tried doing a video mixdown before bring it into Avid DVD – but still no luck. I tried burning to DVD Volume but no luck there. So I asked a co-worker and they suggested using the “Send to” command to send it “DVD One Step” which works except I can’t figure out how to put chapter points on the DVD using this method. So I’m out of ideas; any thoughts (or luck) would be greatly appreciated. My deadline is a few short hours away. Thanks
  • Accountfrozen_needs_realname
    March 29, 2007 at 7:43 pm
    Probably too late now – but I would suggest exporting full QT files, not QT reference files. That most likely would resolve the problem, I would think.
    Jon
    _______________
    Lack of preparation or organization on your part does not constitute an emergency on my part.
