Activity Forums Adobe Photoshop Please Help (batching issues)
  • Please Help (batching issues)
    Posted by David Scott on June 21, 2005 at 11:06 pm
    I really need help with some batching solutions. Because I am doing this for a friend of mine I need to make the process as automated as possible (he’s pretty overwhelmed by PS). If Droplets are the answer all the better. Here is what I am trying to do:
    I have 1 folder containing 25 scans (TIF @ 150 dpi) From each of the TIF’s I need to generate the following:
    a preview image that fits within a given rect (I was using Automate / Fit image)
    a thumbnail consisting of a cropped portion of the scanned image (70 x 100 pixels)
    As far as the thumbnails is concerned, I am having difficulty with pausing the recording of an action and allowing the user to make a selection to crop. I have read you can do this using a crop command but I cound’t make it work.
    Also, if I were to create droplets is there any way to handle the naming of these files. I know how to do this when simply batching, I also know how to do this using the browser but I can’t seem to get a prompt asking me how I want to name my files from a droplet.
    Any ideas or suggestions would be greatly appreciated. Thanks in advance.
    (note: he is on a windows machine running the latest version of Photoshop and XP)
    David Scott
    Mike Gondek replied 21 years, 3 months ago 2 Members · 1 Reply
  • Mike Gondek
    June 24, 2005 at 4:25 pm
    You can decide how to name your new files when using automate >> create Droplet. Just change destination to folder. Your friend will need a folder on his drive with the same name & location.
    You cannot get a file naming prompt to happen in the middle of running a droplet.
    Add an insert stop from the actions palette flyout menu.
    to pause an action during the process to set a marquee selection, click the box in the 2nd column(toggle dialog of the action).
