Activity › Forums › Apple OS X › please help
  • please help
    Posted by Craig Alan on October 4, 2006 at 7:32 pm
    My G4 dual 1 gig is suddenly having problems. It won’t recognize the second hard drive at all. The system drive appears after an extra delay. I get a crossed out circle symbol but after some spinning the system drive boots up. What could be causing this? I’m not out of space and I have repaired permissions. I did experience some weird behavior before this–quicken not finding its file, needed to use back up file, some total system freezes when I needed to reboot. Thanks. Any suggestions?
    Craig Alan replied 19 years, 11 months ago 2 Members · 2 Replies
  • Gunleik Groven
    October 4, 2006 at 10:34 pm
    You could very well be in serious trouble. Sounds like your disk might be dying.
    But there is help – or most often this might help:
    Get Disk Warrior from alsoft.
    Run this on your dying drive. (More often than not, it will get you back up)
    And:
    Buy a new drive and back up all your data!
    Good luck!
    Gunleik
  • Craig Alan
    October 5, 2006 at 5:06 am
    Thanks. Strange that both discs are in trouble on the same day. I opened up the case. Unplugged and reconnected the ribbon. I noticed that the ribbon has a slight vertical tear. Could this be causing the problem? The second drive still does not show up at all. The system drive does after the crossed out circle. I am now backing up the system drive to a laptop. I am going to try the second drive in a firewire case to see if it shows up. I
