Activity Forums Apple Final Cut Pro Legacy PLEASE HELP!
  • Posted by Don Horwitz on February 2, 2006 at 1:00 pm
    i have just upgraded to final cut 5.04. working on duel 2.5 with 2gig ram. i am working on a dv sequence.
    everytime i do a transition there is a shift at the end of it. looks like a phase shift, the frame clunks down a bit. whether using footage or stills i see the shift. i have trashed preferences twice and have tried everything
    i can think of. i dropped the swap fields filter on it and the shift went away, but then the footage looked terrible. i have never seen this happen before. please help! thanks,
    don
    Nick Ryan replied 20 years, 7 months ago 7 Members · 7 Replies
  • 7 Replies
  • Tim Vaughan
    February 2, 2006 at 2:57 pm
    Have you tried deleting your render files?
    Tim
    Tim
  • 24/7films Create COW Profile Image
    24/7films
    February 2, 2006 at 3:25 pm
    i just tried. didnt help. i have just reloaded final cut. still the same problem.
  • Rshdvs
    February 2, 2006 at 4:24 pm
    is the footage bright? i have had this happen before, i adjusted the brightness and it helped. even if the footage is not over exposed.
  • Peter Wiggins
    February 2, 2006 at 4:39 pm
    Proably a field order issue.
    Change your sequence settings to lower for NTSC, upper for PAL, but lower for all DV based editing.
    Peter
    Free Motion Templates
    https://www.peterwiggins.com
    24/7films
    February 2, 2006 at 4:58 pm
    ok….this is very bizare. the only thing that corrects the problem is if i drop
    a filter on the scene. it can be the flicker filter or any of the video filters.
    this seems to shift it up a scan line and take away the problem. if you ask
    me this is a crazy fix……
  • Frank Nolan
    February 2, 2006 at 7:19 pm
    Have you tried rendering the transition?
  • Nick Ryan
    February 2, 2006 at 10:36 pm
    Yeah, you’ve got to render the transition. I had the same problem – I didn’t understand all the ins and outs of preview vs. rendered. Do a “full” render on that section. Go to your drop down, “modify”, “render selection”, “full”. Then select the transition (or a little before and a little after it via in and out points on your timeline), “render selection”, and you’re done. Should work – but, might not.
    Nick
