Activity Forums VEGAS Pro Please could you tell me whats wrong?
  • Please could you tell me whats wrong?
    Posted by Dilsoc Hansen on March 22, 2013 at 1:31 am
    Hey Guys, I am the newest member of you and I usually come to this page when ever I have troubles I actually see that Steve and John are the ones that help the most but anyways I have a BIG TROUBLE with my Sony Vegas Pro
    I use to run Sony vegas pro 11 in a 64 bit 2 GB ram Old PC with Win-7
    I now have Windows 8 64 bit 4 GB ram
    I have tried with sony vegas pro 08 pro 09 pro 10 pro 11 and pro 12 but it wont open…
    it says and I quote
    “Error while starting Sony Vegas Pro
    System Is low on memory reduse the use of memory by closing other aplications”
    …I dont have anything else opened I go to task manager it says 3,5 GB of ram not used… If some one could please help me I would really apreciate it
    For me SVP is really important since I do Youtube videos… Gaming videos actually well thank you…
    Dilsoc Hansen replied 13 years, 6 months ago 6 Members · 9 Replies
  • 9 Replies
  • Phil Seymour
    March 22, 2013 at 5:05 am
    You might look at your paging memory… check the threads for memory paging here, I seem to remember a discussion on “low memory” issues. By default on installation Windows should have set the paging file, but something might have changed it. Worth a look.
    Windows 7 Pro64, i7 CPU, 16GB RAM, SSD boot drive, GTX 570 Graphics, Vegas Pro 12
  • Dilsoc Hansen
    March 22, 2013 at 6:11 am
    Im sorry but where do I check that I am kind of new at this and detailed explanations arent helping me I apreciate it though still could you go a little bit slower?
  • Dilsoc Hansen
    March 22, 2013 at 8:22 am
    hey hum.. Didnt work… there are only 2 guys with the same prob as me and they have no solution
  • John Rofrano
    March 22, 2013 at 10:26 am
    I have Vegas Pro 12.0 running on Windows 8 64-bit with 2GB of memory running in a VMware virtual machine and it works fine. Something about your computer is not right. It would be hard for one of us to determine what you might have done to it to put it in this state but I assure you that if you re-install Windows 8 and then install Vegas Pro 12.0 it all works just fine. I assume you have lots of other software installed and who knows what could be affecting it. Do you have any codec-paks installed? They could mess things up. I would contact Sony since you can’t even get their software to run.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Dave Osbun
    March 22, 2013 at 1:41 pm
    Not sure if this will work with a Windows 8 box, but if there is a ‘Run’ box, type: msconfig
    A window should open, click on the ‘Startup’ tab. Uncheck EVERYTHING that has a check mark EXCEPT your anti-virus software. Reboot the computer.
    Many programs that are installed/downloaded will enable themselves to ‘semi-start’ on computer boot, which uses up system resources- degrading performance. By unchecking their startup they will still open/run fine, but not ‘semi-start’ when you boot up the computer.
    Dave
  • David Alfredo
    March 22, 2013 at 2:07 pm
    good advice Dave, but you know how developers are getting around this? creating keys in the registry so their useless apps run as services linked to svchost… making it hard for the average user to get rid of them, I don’t know why this obsession about pre-loading everything at boot time, really, if I want to use QuickTime or update my Adobe software I can do it manually, no need for the software to be loaded in my system RAM and checking every few minutes for updates and God knows what, irritating !
  • Dave Osbun
    March 22, 2013 at 3:01 pm
    It is highly annoying when developers do this. It’s also a good idea to run ‘services.msc’ and do a cleanup in there. Many are set to ‘automatic’, hence usually run at startup (these are tied to the registry entries you spoke of), so I just set them to manual. I usually ‘sweep’ my system about twice a year. I don’t download much, luckily.
    Dave
  • Stephen Mann
    March 23, 2013 at 4:01 am
    Look at this:
    https://forums.creativecow.net/readpost/24/940494
    Steve Mann
    Steve Mann
    MannMade Digital Video
    http://www.mmdv.com
  • Dilsoc Hansen
    March 26, 2013 at 3:23 am
    hey stephen you are clearly not getting my problem alredy checked hat but thats not my problem… the other guys then I dont know what the problem is I guess I will Install the OS again…if it doesnt work Ill let you know?
