Activity Forums Avid Media Composer Please Advise: Hardware/Software question about Avid Media Composer 8.4.5
  • Please Advise: Hardware/Software question about Avid Media Composer 8.4.5
    Posted by David Carr on March 8, 2017 at 4:42 am
    I have a custom built Mac running an intel i7 sandy bridge with 32gb of RAM. I want to install Avid Media Composer 8.4.5 and cut 2k footage of off a firewire 800 drive.
    question 1: can the i7 Sandy Bridge with 32gb of RAM handle the 2K footage? I think it should be fine, right?
    question 2: what OS is compatible for 8.4.5? does it run on 10.12.3 Sierra?
    question 3: what is the minimum Graphics card set up on this system^ cutting 2K?
    thanks for any input.
    Shane Ross replied 9 years, 6 months ago 2 Members · 3 Replies
  • Shane Ross
    March 8, 2017 at 6:21 am
    [David Carr] “question 1: can the i7 Sandy Bridge with 32gb of RAM handle the 2K footage? I think it should be fine, right?”
    Yes.
    [David Carr] “question 2: what OS is compatible for 8.4.5? does it run on 10.12.3 Sierra?”
    That’s a TAD too new for that version. I’d stick to 10.10 or 10.11 on your Hack for that version of Avid…
    [David Carr] “question 3: what is the minimum Graphics card set up on this system^ cutting 2K?”
    Avid doesn’t really utilize the GPU like Resolve or Premiere. So it won’t come into play here. Drive speed will, and FW800 will be cutting it a tad close..that’s your biggest bottleneck. Just transcode the footage to ProRes MXF or DNxHD and you should be fine.
    Shane
    Little Frog Post
  • David Carr
    March 8, 2017 at 3:00 pm
    Shane,
    Thanks for the advice.
    Here’s a follow up, I know Sierra is only supported for Avid 8.6.5 , but do you think 8.4.5 will Run at least on Sierra? Or is it anyone’s guess?
  • Shane Ross
    March 8, 2017 at 6:34 pm
    Anyone’s guess. The only person who will know will be the first one to try it.
    Shane
    Little Frog Post
