Activity Forums Apple OS X Please advise – Can’t Delete P2 Files
  • Please advise – Can’t Delete P2 Files
    Posted by Peter Tours on February 13, 2013 at 7:06 pm
    I have used P2 for a few years, and I routinely copy the contents folder and lastclip.txt to a new folder on my RAID, and when the project is over and backed up, I delete these folders. Until now.
    As of two projects ago, all P2 cards I’ve copied cannot be moved to the trash – the contents of all the folders in all the cards/folder are locked. I have drilled down thru permissions and there is no reason this files should still be locked.
    They were even edited – that is were assets – in different projects one edited on FCP7 and one PP6 so they don’t even have that in common.
    I can’t even unlock the individual files – of which there are too many to unlock manually – because the lock check box is checked but greyed out on each one. And like I said, I have given everyone, administrator or myself as user (redundant) read and write permission from hierarchically from top to bottom, but the contents of the folders are still locked.
    Anyone know how to unlock and delete these files?
    Peter Tours
    TnT Video Services, Inc.
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Convergence ECS1B 1977-1979
    Sony BVE 500 1979 – 1984
    Datatron Vanguard 1984 – 1993
    GVG VPE141 1993 – 1998
    Media 100 1995 – 2006
    Final Cut Pro 2005 to not too much longer
    Adobe Creative Cloud
    Peter Tours replied 12 years, 10 months ago 2 Members · 2 Replies
  • Rachel Kodner
    October 31, 2013 at 7:24 pm
    I’m having this issue too! Any updates?
  • Peter Tours
    October 31, 2013 at 7:53 pm
    My solution probably won’t help you. About a year ago, I upgraded from 10.6 to 10.7 and kept the 10.6 system drive on a shelf. So I reinstalled it, moving by system back to 10.6.8 and the P2 files on my raid were no longer locked. It was a one in a million shot but it worked. Afterwards I put my 10.7 system drive back and the problem has never recurred.
    Peter Tours
    Fort Lauderdale, FL
    TRI EA5 1974-1977
    Final Cut Pro 2005 2012
