Activity Forums Compression Techniques pleae advice..quicktime …png compression
  • pleae advice..quicktime …png compression
    Posted by Pixel8ted on August 6, 2005 at 8:31 am
    Hi guys,
    Could someone tell me, which quicktime PNG compression setting is lossless, — with filter setting set to none or set to best
    Is this PNG compression quality as good as Animation codec?
    Thanks.
    Pixel8ted replied 21 years ago 3 Members · 4 Replies
  • Charles Simonson
    August 12, 2005 at 4:55 am
    Animation is an Uncompressed codec, and PNG is a comrpessed codec, so Animation should be better. If using PNG, you want to use the None filter.
  • Pixel8ted
    August 12, 2005 at 8:41 am
    thanks .
  • Mactrix
    August 23, 2005 at 3:47 pm
    Animation is a compressed codec as well.
    The compression is lossless with quality set to 100%.
    Animation is 8-bit.
    PNG uses a lossless compression no matter which filtering
    is used. The prefiltering is just a analyse of pixels for
    optimizing the compression.
    PNG ist 16-bit in general but the quicktime-codec seems
    to be limited to 8-bit
  • Pixel8ted
    August 31, 2005 at 7:09 pm
    Hey man !!Thanks a lot for your Input!
