Activity Forums Adobe Premiere Pro Plays back only 6-7 frames at a time!
  • Plays back only 6-7 frames at a time!
    Posted by Adam Taylor on June 24, 2011 at 10:53 am
    Just decided to try out Premiere Pro5 after the debacle of FCPX.
    my system: – MacPro 2x3ghz Quad core intel xeon, 14gbs ram, os 10.6.5, ATI Radeon HD4870, AJA Kona 3, 12Tb Raid over fibre channel.
    I’m having a really strange problem that i have no clue about solving as i have no knowledge of PP.I have tried the following with both an xml import and also a single clip imported.
    I put the clips onto a sequence created using the AJA sequence templates (sd sized), press play and all it will play is around 6 to 7 frames at a time.its not even stuttering – just plays them nice and smoothy then stops until i hit play again and then i get another 6-7 frames only.
    any clues what might up?
    adam
    Adam Taylor
    Video Editor/Audio Mixer/ Compositor/Motion GFX/Barista
    Character Options Ltd
    Oldham, UK
    http://www.sculptedbliss.co.uk
    My YouTube Animations Page
    Dexter Andrada replied 15 years, 1 month ago 4 Members · 6 Replies
  • Chris Knight
    June 24, 2011 at 1:36 pm
    If it’s like my AJA Kona LHe, you’ll have to go into the playback settings, and force it to SD out (otherwise, it’s outputting HD, and trying to conform your SD footage to that in real-time). Playback settings are under the Project menu.
  • Ann Bens
    June 24, 2011 at 3:25 pm
  • Dexter Andrada
    June 25, 2011 at 5:17 pm
    Err, Adam was your question answered by Anne?
    That url was quite helpful
  • Adam Taylor
    July 6, 2011 at 4:03 pm
    sorry for the delay in responding – only just had a chance to re-look at this.
    I think it might have helped, although i have also upgraded to CS5.5 since i asked the question.
    I do find the entire application incredibly slow to respond to any mouse click, though! And talk about a slow startup !! sheesh!
    Adam Taylor
    Oldham, UK
  • Adam Taylor
    July 6, 2011 at 4:04 pm
    thanks for the suggestion.
    Adam Taylor
    Oldham, UK
  • Dexter Andrada
    July 6, 2011 at 5:35 pm
    That is odd, you have a screaming machine there in your possession it should boot up fast and smooth. I suggest that you do the ff:
    1. Boot in safe mode
    2. Run Disk Utility
    3. Verify Permission then Repair then Verify again
    4. Reboot
    If that solves it, holler 🙂
