Activity Forums Adobe After Effects Playout of final project
  • Playout of final project
    Posted by Jen Kessel on February 9, 2012 at 12:34 pm
    Hi there,
    So, I’m pretty new to AE. I just started to really use it within the last couple weeks.
    I have a template that I’m working on right now. Everything seems to work fine. When I scroll the timeline I see everything I have dropped in. When I click on the layers I see each layers with what I have added.
    So, then I render my project. I’m using full res and 16:9. After about 30 min render time. I have a look at the file and it won’t play fully out. It stops on a freeze frame about two seconds in.
    When I scroll the content, I can see my whole project. I just can’t get it to play in real time.
    I have tried different render settings changed it about 4 times now and it keeps on doing the same thing 🙁
    Can anyone help?
    Jen
    Jen Kessel replied 14 years, 7 months ago 2 Members · 2 Replies
  • John Cuevas
    February 9, 2012 at 4:01 pm
    If you are rendering to QT for a broadcast quality playback your computer CPU isn’t fast enough to playback the video. Check out this link:
    FAQ: Why is my output file huge, and why doesn’t it play back smoothly in a media player?
    Johnny Cuevas, Editor
    Thinkck.com
    “I have not failed 700 times. I have succeeded in proving that those 700 ways will not work. When I have eliminated the ways that will not work, I will find the way that will work.”
    —THOMAS EDISON on inventing the light bulb.
  • Jen Kessel
    February 9, 2012 at 7:50 pm
    Thank you, I will have a look and hopefully it will work 🙂
    Cheers
