Activity Forums Apple Final Cut Pro Legacy Playing out an HD sequence to an SD tape
  • Playing out an HD sequence to an SD tape
    Posted by Aliya Al-hassan on January 25, 2011 at 1:44 pm
    Hello,
    can someone help?
    I have an HD sequence ( 1920 x 1080, 1080i)which I am trying to play out to an SD tape (don’t have an HD deck at mo).
    The playout seems to freeze on one shot but the audio is fine. It also seems to be letterboxed.
    Can someone suggest what I can do so it plays out normally (16:9) to SD tape?
    I have tried creating a new SD timeline and importing the edit into that but all the edges of the footage become jagged.
    thanks
    Jeff Greenberg replied 15 years, 7 months ago 3 Members · 2 Replies
  • Chris Tompkins
    January 25, 2011 at 4:44 pm
    You need a Video I/O card for this.
    Alternatively you can output your HD timeline to a file and drop that into Compressor and create a 16X9 SD file and bring that back into FCP and lay out to SD tape.
    Chris Tompkins
    Video Atlanta LLC
  • Jeff Greenberg
    January 26, 2011 at 12:46 pm
    If you have a firewire based system, FCP can’t push the HD stream down the firewire chain). Actually it can for HDV, but you ant an SD out.
    Nest your sequence in a DV sequence. Yes, it will be letterboxed (well, HD is 16×9 and SD is (mostly) 4×3. Square peg, round hole.) If you don’t mind losing the sides, you could blow this up. This will output from FCP, but will likely require rendering for output.
    Best,
    Jeff G
    Apple Master Trainer
    Avid Cert. Instructor DS/MC
    Avid & Color Videos Vasst.com
    Compressor Essentials Lynda.com
