Activity › Forums › Blackmagic Design › Playing image sequences off the Premiere Pro timeline?
David Mack replied 19 years, 3 months ago 6 Members · 14 Replies
Jeff Brown
June 1, 2007 at 1:19 pmThe “folder technique” is the only documented (by BlackMagic) method I’m aware of. I think it’s in their manual?
I have tried using FrameLink, but it seemed untenable for my workflow. Can’t remember why, but it ended up being easier to render to AVI.
I don’t find render-to-AVI to be a killer, but my stuff is usually less than 1 minute.-jeff
Brett Howe
June 6, 2007 at 6:35 amHi David
I have not tried this myself, but it just occured to me while I was reading your thread. Have you tried the folder method, onto the timeline, then create a new sequence, and nest the original? This would enable you to edit like normal, without having to pre-render to BM AVI’s. Your suystem should be grunty enough for this…. I’ll give it a go myself when I have a chance.
Brett
David Mack
June 6, 2007 at 7:09 amHi Brett,
OK, you’re going above my Premiere Pro knowledge now! I’ve not done ‘nested’ things before. I’ll have to look into that. Let me know if you have any luck – sounds like a plan!
I’ve still not heard back from BMD – normally they’re very good at responding to support emails?
David Mack
June 11, 2007 at 10:49 amHas anyone tried HD image sequences straight off the Premiere Pro timeline using the eclipse rather than MBE?
