Activity › Forums › Blackmagic Design › Playing HD in FCP and output it to SD monitor problem on Decklink
  • Christian Betong
    August 25, 2007 at 11:18 am
    I have have found what produces this problem.
    It happens when i have a sequence in a sequence in FCP in HD. Both have 1080i 25fps proreshq timeline settings.
    When I go into the sequence that i have in my timeline it plays properly.
    Has anyone else had problems with this. I havent played around with other HD timeline settings, but it should play correctly, shoulden
  • Kristian Lam
    August 27, 2007 at 6:17 am
    Thanks for the report. We’ll be checking this one out.
    regards
    Kristian Lam
    Blackmagic Design
  • Sam Goetz
    August 27, 2007 at 7:55 pm
    I’m having the same exact problem! On FCP 5.0.4 OR 6 w/ BM 6.3 OR 6.4 drivers w/ HD or SD cards!
    I’m playing 720p23.976 media out via SD downconversion and the video is resizing rapidly and then crashing FCP. 1080 downconversion looks great as does 720p native on an HD display.
    I was able to fix the problem by downgrading back to the 6.2 drivers, but YES this is a confirmed issue. THE 6.3 & 6.4 DRIVERS CANNOT DOWNCONVERT 720P. For now, I’m staying away from the new drivers.
    Sam
  • Kristian Lam
    August 27, 2007 at 11:19 pm
    Sam,
    Send us a copy of the FCP crash log please. Thanks
    support[at]blackmagic-design.com
    regards
    Kristian Lam
    Blackmagic Design
  • Sam Goetz
    August 28, 2007 at 3:32 pm
    Where would the crash log be?
  • Kristian Lam
    August 28, 2007 at 11:17 pm
    ~/Library/Logs/CrashReporter/
    It will be called “Final Cut Pro.crash.log”
    regards
    Kristian Lam
    Blackmagic Design
  • Sam Goetz
    August 30, 2007 at 9:29 pm
    I see no such crash report…. maybe that’s because it’s more like a “freeze” than a “crash.” Basically, I get the spinning volleyball of death, and even after waiting 10 minutes or more nothing happens so I’m forced to do a force quit. I don’t think logs are created when you force quit.
    Apologies for the confusion. It’s a freeze not a crash…
