Activity › Forums › Sony Cameras › Playing Edited Footage on PMW-EX1
Rafael Amador replied 17 years, 6 months ago 6 Members · 20 Replies
Craig Seeman
January 23, 2009 at 4:36 pm[Rafael Amador] “the truth is that the first time was taking too long to download the video”
This is a new COW feature. Unfortunately there are issues with playback. The tutorial I uploaded was only about 6MB which should be very fast playback. It seems COW makes the file size much larger or has a slow buffer issue.[Rafael Amador] “As you did it I think is interesting when dealing with independent clips, because you keep the original clip name and TC. “
One reason to keep the original is that you have to change stereo audio to dual mono as XDCAM MP4 and MXF will only handle mono audio tracks.I’d be posting more tutorials but yes, playback is painfully slow even with very small file size.
Rafael Amador
January 23, 2009 at 4:49 pmHi Craig,
Is not the fault of the video, is just the speed that my Internet connexion allow me tonight.
BTW it’s supposed to be a 4GBs limit when exporting to XDCAM. had you tried to export more than that?
As you point you need to change the audio to two mono channel to export. I had to do the same to the sequences I exported. Mostly I’ve been uploading to the SxS card to recapture as SD in Proress. Pefect and fast downscaling.
Cheers,
rafael -
Baz Leffler
January 24, 2009 at 2:36 amAnother great if not unknown feature of this ‘timeline to XDCAM to SxS to camera’ treatment is that the timeline’s timecode is embedded into the final media file – and more important, when you play it on the camera out the HD-SDI connector to a HDCAM deck switched to ‘sdi timecode’ your original timeline timecode becomes the HDCAM’s master timecode – W A Y T O G O ! ! !
Baz
What would I do without the ‘UNDO’ button!!!!
Christoph Zarfl
February 22, 2009 at 9:27 amI found some articles which say that it works – but none of the articles says how it works – so if anybody knows please let us know!
Thank you Chris
Rafael Amador
February 22, 2009 at 12:49 pmJust put the EX-1 footage in an EX-1 sequence and hit “Export to SONY XDCAM”.
Just be careful don’t try to export more than 4GB.
rafael -
Christoph Zarfl
February 22, 2009 at 7:12 pm -
Craig Seeman
February 22, 2009 at 7:33 pmMake sure you have most recent versions of Sony software.
ClipBrowser 2.00.01
XDCAM Transfer 2.8.0
Final Cut Pro 6.0.5
Make sure you’re using an XDCAM EX easy setup.
Select the Sequence and use Sequence Settings and make sure Audio Output is set to Dual Mono -
Christoph Zarfl
February 22, 2009 at 7:58 pmThank you very much!!!
After updating to XDCAM Transfer 2.8.0 it worked!
Thank you – that makes me supe happy 🙂 !!!
Christoph Zarfl
February 23, 2009 at 9:17 amDo you know if the EX1 has embeded Audio on the SDI outputs?
I want to conect it to a “digibeta” – do you know if there are any problems?Thank you very much chris
Rafael Amador
February 23, 2009 at 10:35 amHi Christoph,
Yes you have the two audio channels embed in the SDI.
I haven’t tried to capture to DigiBeta, but I did capture through the AJA ioHD to my Mac.
Works great.
rafael
