Activity Forums DaVinci Resolve Playing back timeline in C-sort mode?
  • Playing back timeline in C-sort mode?
    Posted by Robert Glanns on September 22, 2011 at 3:01 am
    Is it possible to play back all the shots in my FCP-imported timeline in true C-sort mode?
    I know I can switch the Color timeline to “Source” and display the thumbnails in C-mode, but if you actually play the timeline in this mode, it will still play back with the original edit sequence mode.
    Dean Manion replied 15 years ago 7 Members · 8 Replies
  • 8 Replies
  • Charlie Edison
    September 22, 2011 at 8:39 am
    True C-mode with reel numbers doesn’t work properly,
    The work around is in the conform page right click on your session and choose “create session with handles” (handles being zero) this will give you a true C-mode sort!
    Hands up who would like the C-mode function fixed where the time line sorts first by reel number and then by timecode..
    Me! – that’s 1
  • Nedeem Al-astrabadi
    September 22, 2011 at 11:11 am
    Try holding ‘Command’ and press the ‘page up’ and ‘page down’ buttons to toggle between A and C mode. That should do it.
  • Gabriele Turchi
    September 22, 2011 at 2:10 pm
    Nice trick charlie !
    yes +1 for a “sort by clip reel/name mode”…
    g
    Davinci Resolve Control Surface
    MacPro
    Cubix desktop 4
    2 Red Rocket
    GT120+GTX470+GTX285
    24GB RAM
    HD Dreamcolor
    Panasonic 58PF Plasma
  • Sascha Haber
    September 22, 2011 at 2:50 pm
    Absolutely, gets my vote…
    TC only is useless, I have like 80 days of shooting in this project.
    Reel ID is MUST
    A slice of color…
    DaVinci 8.0.1 OSX 10.7
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB eSata 6TB
    GTX 470 / GT 120
    Extreme 3D+ WAVE
    http://www.saschahaber.com
  • Joseph Owens
    September 22, 2011 at 3:05 pm
    That toggles between Record and Source, but for some reason, my AAF imports are still displayed with handles — ie I can’t see my original edit in any mode.
    jPo
    You mean “Old Ben”? Ben Kenobi?
  • Robert Glanns
    September 22, 2011 at 5:18 pm
    I know you can switch the timeline sort to C-mode, as I already mentiones in my original post.
    The problem I was asking about is that this mode is only useful for visually sorting the timeline, and not actually playing it back in c-mode.
  • Dean Manion
    September 24, 2011 at 6:20 pm
    This has been a huge oversight since the first build. I’ve been very frustrated with the lack of a true C-mode sort. Toggling the up/down arrow simply sorts in source code order, with NO source reel sorting. This makes it completely useless for most long form work.
    True C-mode sorts the reel names first, then the source code, so all the clips from the same reel are lined up. This is imperative for correcting by reel first, then fine tuning by clip. In a Preconform workflow this is the only way to correct based on reels. Not having it is a huge disadvantage.
    BMD, PLEASE FIX THIS!! Pleeeeease!
  • Dean Manion
