Activity Forums Panasonic Cameras Playing back 59.94 @ 23.98 in AJ-1200?
  • Playing back 59.94 @ 23.98 in AJ-1200?
    Posted by Christopher Macintosh on May 8, 2008 at 11:37 pm
    Hey There,
    I am using a Panasonic AJ-1200 to record 59.94 timecode and picture from a pulled down 23.98 source from a Sony JH-3. I understand the AJ-1200 then has the ability to play back the recorded 59.94 picture @ 23.98. Is this possible? If so, what are the correct deck settings for recording as well as playback (if they differ).
    Thanks a Million,
    C. M. Neil
    Jesse Rosen replied 18 years, 4 months ago 2 Members · 1 Reply
  • Jesse Rosen
    May 9, 2008 at 2:00 am
    The 1200a will play back 720P that has 24 over 60 (or 23.98 over 59.94) as 1080/24psf, but it will not do the same for 1080i.
    The newer P2 mobile (HPM110) will remove the pulldown from 1080i stream, however and output 1080Psf, so if you have access to one of those you could use it in line with the 1200 to get 1080Psf.
    Jesse Rosen
    Director of Technical Development
    Abel Cine Tech, Inc.
    http://www.bustedskull.com
