Activity Forums Live Events & Streaming Playing and Synching 12 video streams
  • Playing and Synching 12 video streams
    Posted by Miki Shalom on December 12, 2010 at 12:18 pm
    Thank you for the knoledgeble responses,
    now, turns out things will end up little different than what was initially planned (i am not surprised). I am now looking into synching 12 different videos which will run on 12 different laptops.
    will, again, appreciate if you could share your knowledge.
    thanks,
    Miki Shalom
    Hello there,
    I’m due to start a project soon which will require playing a number of videos streams (from 1 to 4) on 12 different video screens. The base setting I had in mind was 4 PCs, each with a Matrox 3 monitor multi display adapter. And BTW, they need to be in sync.
    given that, my questions are:
    Can I use the matrox card to send the same video signal to all 3 monitors connected to the same station or do I need a system that can play 3 streams simultaneously (one for each screen)?
    Should I consider a video splitter instead of a multi display adapter?
    Thomas Leong replied 15 years, 9 months ago 3 Members · 2 Replies
  • Walter Soyka
    December 13, 2010 at 2:22 am
    [Miki Shalom] “I am now looking into synching 12 different videos which will run on 12 different laptops.”
    I’d suggest Dataton WATCHOUT, if you’re running PCs. You can rent the license keys from many staging companies.
    If you’re running Macs, Renewed Vision Pro Video Player should do what you need.
    Walter Soyka
  • Thomas Leong
    December 13, 2010 at 2:34 am
    Since it is 12 different videos, frame-accurate sync may not be absolutely necessary. Have a look at the freeware from Multiscreener from https://www.zachpoff.com/software/
