Activity Forums Adobe Premiere Pro Playing 60p in a 24p Sequence
  • Playing 60p in a 24p Sequence
    Posted by Jeremy Logan on January 16, 2014 at 12:05 am
    I shot two types of footage on my Canon t3i this weekend: 1920 x 1080 at 24p, and 1280 x 720 at 60p.
    I want BOTH types of footage in the final product. Right now, the 60p footage plays like 60p in a 60p sequence (smooth, “real”, etc.), and the 24p plays like 24p in a 24p sequence (unhurried, cinematic); the problem is that when I drop the 60p footage in the 24p sequence, it doesn’t play like 60p, it plays like 24p.
    Premiere Pro isn’t letting me use the ‘interpret footage’ command on the 60p footage once it’s in the sequence, but it IS recognizing the 60p frame rate while it’s still in the bin.
    How do I get both types of footage to play in the distinct frame rates that I shot them in while being in a uniform sequence?
    PS: I’m not looking for slow motion.
    Jeremy Logan replied 12 years, 8 months ago 2 Members · 2 Replies
  • Shane Ross
    January 16, 2014 at 2:00 am
    [Jeremy Logan] “Right now, the 60p footage plays like 60p in a 60p sequence (smooth, “real”, etc.), and the 24p plays like 24p in a 24p sequence (unhurried, cinematic);”
    Yup yup yup…that’s how it works.
    [Jeremy Logan] “the problem is that when I drop the 60p footage in the 24p sequence, it doesn’t play like 60p, it plays like 24p.”
    Well, of course not. Because the sequence is 24p. The footage plays back at the frame rate of the sequence, because it has more frames than the sequence, frames are removed.
    [Jeremy Logan] “How do I get both types of footage to play in the distinct frame rates that I shot them in while being in a uniform sequence?”
    Use a 60p sequence, and add the 24p footage. It’ll still play back at 24p. Because it can’t ADD frames to make it smooth. It’ll still be 24fps, and the 60p will still be 60fps.
    Shane
    Little Frog Post
  • Jeremy Logan
    January 20, 2014 at 12:19 am
    Oh nice, that makes sense! A sequence with a lower frame rate than the footage will drop frames. And what about export settings? I usually just use the HD 1080p preset… and it doesn’t look like there is a HD 720p 60fps one. Any recommendations?
