playhead scrubbing lag with 4K footage
Greetings,
I am trying to edit 4K XAVC-S footage on my Power Mac tower (specs below) and basically wondering what my limiting hardware factor is that I can upgrade that would enable me to edit and scrub footage more smoothly, or if it’s even possible. I edit on Premiere Pro CC.
The problem:
I have a mid-2010 mac tower and am basically working on a dance documentary with over 100 hours of footage, most of it 4K XAVC-S from Sony a7sii. I AM able to play, edit, and export single or multiple tracks of video. But my sticking point is when it comes to scrubbing the footage, it take 3 to 5 seconds (sometimes more) to bring up the next frame when I move the playhead. I can technically edit and it plays ok, but there is significant enough lag that it inhibits my creativity and efficiency.Generally, I work in a 1080p, 23.976 timeline and “set to frame” the 4K footage. Part of the footage is 1080 59.94, which edits more smoothly. Usually my resolution is set to ½ or Full.
The Question:
What is the most important thing to upgrade so that I could scrub more efficiently?What is the most likely problem (aside from codec) causing lag in scrubbing video?
(NOTE: I realize that the number one answer would be to transcode xavc-s to an edit friendly codec like prores or cineform, but given my massive amount of footage, I am loathe to do that, for storage and time reasons. I am editing on my own and it’s taken months to just to organize all the footage to this point, so am really hoping there’s a way to power through with the xavc-s. I could bite the bullet and buy some more drives, and spend next couple months transcoding, but really want to avoid if possible. Even prores proxies are much much bigger than the original files.)
Here are the areas I wonder about and the things I’ve tried so far:
External drive connection?
I upgraded USB 2 to USB 3 ports on the back. This helped with transfer obviously, and I notice less lag with editing in general, but still tons of lag in the scrubbing. I can’t use thunderbolt with this processor, so should I try upgrading processor and installing thunderbolt to use thunderbolt drives?External hard drive?
I bought a 12TB Western Digital raid drive (2×6) but the disks are 5200 rpm. It helped a bit, but the lag’s still there. Should I try to find a 7200 raid drive that uses USB 3? Or again, upgrade to thunderbolt somehow?Memory / RAM?
I upgraded my memory from 8GB DDR3 to 16GB. Seemed to help some, but would upping it to 32 or even 48 help even more?
Video card / GPU?
Should I upgrade my video card from the original ATI Radeon?Thank you for any advice. And if there is a better forum to post to, please let me know.
Mac Pro (Mid 2010)
3.2 GHz Quad-Core Intel Xeon
16 GB 1066 MHz DDR3
SSD SIERRA 500GB (OS, apps) / HDD 1TB
ATI Radeon HD 5770 1024 MBOSX Sierra 10.12.6
External Drive: 12 TB (2×6) WD 5200 Raid Duo, USB 3.1
Adobe Premiere Pro CC 2018
