Activity Forums Adobe Premiere Pro Playhead returns to beginning when sequence tab is activated
  • Playhead returns to beginning when sequence tab is activated
    Posted by Charlie Kosheff on March 18, 2019 at 2:57 pm
    When copying and pasting interview clips between sequences for a project (as in sorting clips into topic sequences)- the playhead always returns to the first frame of each sequence when I select the tab. This is annoying when you’re trying to stick clips at the end of sequences to sort them.
    Can I not work this way? Do I have to create subclips and stick them in topic bins instead>?
    Charlie Kosheff replied 7 years, 6 months ago 1 Member · 1 Reply
  • Charlie Kosheff
    March 18, 2019 at 8:07 pm
    Right so I have to click “end” every time. It’s too bad because it’s right at the end where I need it when I activate the sequence and then BAM it moves to the head for no reason by itself.
