Activity Forums VEGAS Pro Playhead Placement Problem
  • Playhead Placement Problem
    Posted by Konriar on April 26, 2007 at 4:57 pm
    While viewing my project, whenever I find the place I want to stop and edit at, I hit pause and the playhead jumps back to where it started playing from. Is there a way to get the playhead to stop where I hit pause?
    Don Bloom replied 19 years, 4 months ago 3 Members · 2 Replies
  • Edward Troxel
    April 26, 2007 at 5:20 pm
    That’s the normal behavior when you use the space bar. If you use the enter key instead, it will do what you want. However, I like the space bar to do that too. So… go to Options – Preferences and turn on the option to “Make Spacebar/F12 Play/Pause instead of Play/Stop” (or something like that).
    Edward Troxel
    JETDV Scripts
  • Don Bloom
    April 26, 2007 at 7:18 pm
    Or you can use the J-K-L keys K will stop it on th emark as well.
    Either or!
    Don
