Activity Forums Apple Final Cut Pro Legacy Player window is white
  • Player window is white
    Posted by Spencer Schilly on September 20, 2007 at 2:59 pm
    Whenever i stop my timeline/sequence player the window to the right goes white… I’ve looked at my view settings and it all seems okay. i did a print to tape last night and wonder if i messed up a setting….
    Spencer Schilly replied 18 years, 11 months ago 3 Members · 3 Replies
  • Shane Ross
    September 20, 2007 at 3:03 pm
    Shane’s Stock Answer #15:
    Make sure the canvas or viewer are selected then go to VIEW>CHANNELS and set it to RGB. It might be set to ALPHA.
    Shane
    Littlefrog Post
    http://www.lfhd.net
  • John Czerwinski
    September 20, 2007 at 3:12 pm
    I’m guessing you are referring to the window on the right as the canvas. If so, the 3 little buttons on the top of the canvas window. left button(screen size) middle button(snyc off, open, gang). The right button may be checked alpha instead instead of RGB. change to RGB
    Good luck
  • Spencer Schilly
    September 20, 2007 at 3:21 pm
    that was it. thank you!!
