Activity Forums Adobe After Effects Playback/Render Off by 1 frame, have to predict it
  • Playback/Render Off by 1 frame, have to predict it
    Posted by Jeff Rouric on April 6, 2013 at 7:31 am
    Hi, I’ve noticed something start happening in AE CS6. It seems that when I’m adding an effect to a layer or another layer to appear at a certain time, I set everything all right in the workspace, and everything is fine. But then I go to render, and it looks like said layer appears/leaves 1 frame earlier than it’s supposed to. This happens no matter what codec I use to render. I’ve started just moving the effect/shape/layer by one frame to predict it. That’s the only way it works. But it shouldn’t be this way, what can I do?
    Jeff Rouric replied 13 years, 5 months ago 2 Members · 2 Replies
  • Tero Ahlfors
    April 6, 2013 at 7:54 am
    The work area out point is inclusive. Zoom in the work area and make sure the layer and out point are correct.
  • Jeff Rouric
    April 6, 2013 at 8:10 pm
    Hey Tero, thanks but I don’t think that’s the problem. I was tired and could barely explain it last night, so today I made this short video outlining the problem. The text is supposed to show up and disappear at EXACTLY the timecode it says, and it does when it’s being played in the workspace, but it is off by a frame upon render.
    https://www.youtube.com/watch?v=t0jftfnx_h4&feature=youtu.be
    And here is a pic of the workspace, maybe you see something…these are usually screen caps from Quicktime Player, maybe there’s something wrong with those kinds of clips.
    https://i.imgur.com/Ofahbrk.png
    View post on imgur.com
