Activity › Forums › Apple Final Cut Pro Legacy › playback video freezes but audio continues
Posted by Jean Gindreau on August 18, 2006 at 3:19 pmHi
Captured to data drive. Finished editing. When triing to record to VCR, playback video freezes but the audio continues fine. It’ll stay on the frozen frame forever but the audio continues.
thanks
Navig8r replied 20 years ago 4 Members · 3 Replies -
Chris Poisson
August 18, 2006 at 3:53 pmJean,
Without knowing your project or system settings, here’s a few guesses:
Your canvas and/or viewer are not at fit to window or may be overlaping your timeline.
Under View you are not set to view all frames.
Also under View, your video playback may not be set correctly.
Also under View try refreshing audio visual devices.
Lastly under the FCP menu check your playback device settings.
Thaxter Clavemarlton
August 19, 2006 at 1:17 amThere is a function in FCP that is often overlooked… and it can help with many audio and video “skipping”, “sticking” and “missing” problems.
You should “Mixdown” the Audio for playback before you dub out of FCP, or during the edit, if you have audio/video stuttering, drop-outs, sync-slippage, or freezes.
NOTE: Mixdown has even been demonstrated to help with slipping, skipping problems (or “missing” audio clips) for files being EXPORTED as QT (or similar) files out of FCP.
First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
Sequence Menu > Render Only > Mixdown.
You should see a dialog box telling you its rendering.
It might seem to make little sense that “Mixing down” even simple audio tracks will “fix” complex video “freezes” or random audio dropouts to tape or export, but it CAN.
NOTE: It does not matter of you only have one audio track, if there are random freezes during output, you should try the Mixdown.
Navig8r
August 23, 2006 at 1:24 pmI have the same problem during capture. I originally thought it was just the playback, but it’s in the capture. I’ve had to manually go in and sync the audio after ech video stick.
Why would the capture video stick and the audio be fine?
thanx
