Activity Forums Adobe Premiere Pro playback too fast
  • playback too fast
    Posted by Rick Van den berg on August 29, 2014 at 10:56 am
    Hi, so i’ve got this problem, when i press space the timeline is playing back way too fast , im aware i can press j,k and l to change the speed of the playback, but i can only get it to playback even faster or in reverse..
    i did some tests with different projects, and it seems it ONLY happens with palDV timelines (xdcam material). when i drag the material into a HD timeline(prores/h264 or whatever), it plays back fine.
    also, when i open the project on another computer it also plays fine.. so i guess its something with my premiere version or os. i also cant remember this happened before. im on premiere cc2014 with the latest update.
    it really looks like a bug or just a one click fix. i just cant figure it out…. really annoying.
    any suggestions?
    Rick Van den berg replied 12 years ago 2 Members · 2 Replies
  • Ann Bens
    August 29, 2014 at 2:00 pm
    When Premiere is acting weird, restart computer then hold down shift+alt while opening Premiere until welcome screen.
    See if that will help.
    Adobe Certified Expert Premiere Pro CC
    Adobe Community Professional
  • Rick Van den berg
    August 29, 2014 at 3:18 pm
    it worked! thanks !
    edit: well kind of, turned out it has something to do with the blackmagic playback, when i checked it on again (after the reset turned it off by default) it went tripping again. well im a step further
