Activity › Forums › Adobe Premiere Pro › Playback though HD tV through Blackmagic HDMI OUT
Posted by Greg Burke on April 5, 2012 at 2:54 amCan’t seem to figure it out, IN final cut its rather simple PPRO seems to be a little different. Any thoughts on how I can get A feed though the HDMI out for my Client Monitor? Thanks!
I wear many hats.
http://www.gregburkepost.comTom Daigon replied 14 years, 5 months ago 5 Members · 8 Replies -
Shane Ross
April 5, 2012 at 6:11 amInstall the BMD drivers for Adobe. And then use a BMD sequence setting. CS5.5 only outputs via the hardware when you use a sequence setting for that hardware.
Shane
Little Frog Post
Read my blog, Little Frog in High Def -
Greg Burke
April 5, 2012 at 10:33 amDo you have a Link I found a BM 9.1 drivers on BM’s website but no specific drivers for Adobe.
I wear many hats.
http://www.gregburkepost.com -
Chris Tompkins
April 5, 2012 at 10:51 amDid you install CS After you already had the BMD installed?
Then, install the latest BMD driver after installing CS.
Then, use a BMD sequence when creating a NEW sequence and it will feed out the card.Chris Tompkins
Video Atlanta LLC -
Greg Burke
April 5, 2012 at 8:02 pm -
Paul Gibbens
April 18, 2012 at 2:44 pmI’m having the same problem,I can’t get adobe premier cs5.5 to play back through an external monitor. I’ve done everything listed above.
Please help.
Chris Tompkins
April 18, 2012 at 2:59 pmYou have to start with a BMD sequence, in the “New Sequence” section for it to play out the card.
Chris Tompkins
Video Atlanta LLC -
Paul Gibbens
April 18, 2012 at 3:18 pmBeen There, Done that… any idea what next? I’ve done everything in this thread.
Tom Daigon
April 18, 2012 at 3:44 pmIn CS6 this has all been resolved. Just create a regular sequence and with the magic of Adobe Transit (built into the PrP software) it will playback through third party hardware like my Kona 3 with ease. And you get all the CUDA goodness from that sequence as well. A major achievement!
Tom Daigon
PrP / After Effects Editor
http://www.hdshotsandcuts.com
Mac Pro 3,1
8 core
10.7.3
Nvidia Quadro 4000
24 gigs ram
Maxx Digital / Areca 8tb. raid
Kona 3
