Activity › Forums › Adobe Premiere Pro › Playback stutters while transitions, especially at slower speed.
  • Playback stutters while transitions, especially at slower speed.
    Posted by Oma Be on January 26, 2015 at 10:14 pm
    Hi there!
    So here’s my issue. When I transition between two clips the playback stutters even after rendering, even after exporting. I tried many many things to resolve the issue and the problem is still there. If I remove the flickering to each scene, it’s less problematic but it still remains.
    It’s hard to explain exactly how it stutters but I do recall the issue being there in an old project which I will share a link. The problem resurfaced in a project I am currently working on, it would be really swell if I can resolve it before exporting this time.
    here is the previous project : https://vimeo.com/88574174
    Issue at transition :
    00:44 – 00:46
    01:08 – 01:10
    02:58 – 03:07
    (Although I have partially resolved that one by pausing scene B of the A-B transition so the stuttering that appears only comes from scene A)
    03:52 – 03:56
    What can I do to resolve the issue?
    Cheers
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
    Richard Herd replied 11 years, 8 months ago 2 Members · 5 Replies
  • Richard Herd
    January 27, 2015 at 12:21 am
    Honestly it is not a bad effect 🙂
    To me, it looks like your VFX and live action are in different frame rates and the dissolve is rendering between them.
  • Oma Be
    January 27, 2015 at 1:10 am
    🙂 well it does give a je-ne-sais-quoi from an exterior point of view but from my point of view , it isn’t as I want it if you get what I mean .
    To understand properly, basically you’re saying that my Sequence/timeline’s frame rate and the original video’s frame rate are different correct?
    If so, I can assure you it is exactly the same.
  • Richard Herd
    January 27, 2015 at 6:26 pm
    [Oma Be] “To understand properly, basically you’re saying that my Sequence/timeline’s frame rate and the original video’s frame rate are different correct?
    If so, I can assure you it is exactly the same.”
    No. That’s not what I’m guessing. I’m guessing: The visual-effects-render and the camera-footage are different.
  • Oma Be
    January 28, 2015 at 4:00 am
    it’s not 🙁 I mean it isn’t different.
    Thanks though.
  • Richard Herd
    January 28, 2015 at 9:28 pm
    Is one of them time remapped a bit?
