Activity Forums Avid Media Composer Playback stops at one particular point.
  • Playback stops at one particular point.
    Posted by Sean Lennon on May 22, 2019 at 1:38 pm
    Its very strange, I play through my timeline, and at the exact same point each time, playback stops (no in and out selected) without fail. I Have to scroll past the point each time to get it to play again. Any thoughts on why this may be happening?
    S
    Jeff Cronenberg replied 7 years, 3 months ago 2 Members · 2 Replies
  • Sean Lennon
    May 22, 2019 at 1:43 pm
    Also, when playing using the L key, it sometimes causes the position indicator to move back to the very start of the timeline.
  • Jeff Cronenberg
    May 23, 2019 at 11:55 am
    I have had this happen occasionally when I have fast-imported ProRes into an Avid project, every once in a while a clip gets corrupted somehow and stops at the same point every time. The only workaround I ever found was to re-import the clip, not as a fast import, but as a full DNxHD145 import. Hope this helps.
