Activity › Forums › Apple Final Cut Pro Legacy › playback starts fine, then begins dropping frames…finally halts playback
  • playback starts fine, then begins dropping frames…finally halts playback
    Posted by Jason Brown on June 23, 2010 at 8:17 pm
    I’m a fairly experienced FCP editor and I can’t figure this out.
    FCP7 – Matrox MXO2 – Snow Leopard – XDCAM 420SP (wrapped in Apple HDV 30p 1440×1080 container)
    I’ve ran speed test – average read/write of 230 MB/s
    Running on internal software RAID-0 (3TB, 300GB free)
    Everything seems to be up to date regarding MXO2 firmware. I’ve rebooted, running no other programs. It seems to run faster if I let FCP sit idle for a couple minutes…it will play longer without issues than if I keep trying to play over and over. I’m wondering as I’m typing this…how much space do you need free on a RAID? It seems to be a bottleneck issue.
    I’ve had this issue before, and it’s resolved itself. I’m hoping someone has some insight.
    -Jason
    Jason Brown replied 16 years, 3 months ago 4 Members · 7 Replies
  • 7 Replies
  • David Roth weiss
    June 23, 2010 at 8:20 pm
    Your RAID is simply too overloaded.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    EPK Colorist – UP IN THE AIR – nominated for six academy awards
    A forum host of Creative COW’s Apple Final Cut Pro, Business & Marketing, Indie Film & Documentary, and Film History & Appreciations forums.
  • Steve Eisen
    June 23, 2010 at 8:21 pm
    Only 300GB free on a 3TB Raid? That’s not much room left.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Francois Stark
    June 24, 2010 at 6:39 pm
    I don’t think it is your raid array. You did not specify your CPU or RAM. Are you on a g5?
    HDV takes a lot of CPU power to decode and play in real time. I would suspect your CPU of not being fast enough – even the newer Inter machines battle to do HDV.
    XCDAM 420 wrapped in a HDV container…
    What is your timeline settings? HDV is always a bugger… I would suggest converting all your HDV to Apple Prores or DVCPRO HD for far better playback performance.
    Or place your HDV clips on a Apple Prores timeline and render.
    Regards
    Francois
    Regards
    Francois
  • Jason Brown
    June 24, 2010 at 7:37 pm
    16 gig of ram…not sure of g5…but it’s 8 core, purchased highest end Mac u could buy 1 year ago. Regarding codec, that is the container I get when I rewrap the mxf files off the xdcam disc with the 420sp setting on a PDW700.
  • Jason Brown
    June 24, 2010 at 7:38 pm
    And…sequence settings match clip.
  • Francois Stark
    June 25, 2010 at 12:08 pm
    Hi Jason
    No, then it is definitely not your CPU or ram….
    How did you bring the footage into FCP? Log-and-transfer would normally transcode incoming footage into Apple Prores. If you used the Sony import program you are stuck in their codec. HDV sucks. I would try to transcode overnight – use Media Manager to go to Prores.
    Hope it helps
    Regards
    Francois
  • Jason Brown
    June 25, 2010 at 5:38 pm
    [Francois Stark] “Log-and-transfer would normally transcode incoming footage into Apple Prores.”
    I use the XDCAM transfer import function…which does NOT transcode, but wraps the video in a different container than the native MXF format from the disc. I can shoot in 3 formats on the disc – 422 50 / 420 HQ / and 420 SP. The 422 50 comes in with an “Apple XDCAM HD codec” but the 420 SP comes in with that HDV codec.
    I need to figure out how to come off the xdcam disc with a less compressed codec, but there aren’t any options coming through XDCAM transfer.
    -Jason
