Activity › Forums › DaVinci Resolve › playback, start of clips show no correction for 1 second
  • playback, start of clips show no correction for 1 second
    Posted by Justin Lovell on December 2, 2011 at 3:38 pm
    I’m sure there is a quick solution for this..
    I applied color correction to a number of clips that I have scene detected. Now when I play the clips, when it hits the first frame of the clip, it shows the clip without color correction, then the correction flips on.
    Is there a way to toggle it so the correction stays on for the whole clip?
    Justin Lovell /Assoc. CSC
    cinematographer//
    8/16mm>2K.transfers
    http://www.framediscreet.com
    Sascha Haber replied 14 years, 10 months ago 3 Members · 4 Replies
  • Ola Haldor voll
    December 2, 2011 at 3:41 pm
    Sounds like it’s a frame off really. Did you check the scene detection after it was done analyzing?
  • Justin Lovell
    December 2, 2011 at 3:47 pm
    ah, it appears I have somehow added markers to all my clips notching the correction to start into the clips. Do you know how I may have done that to all of my clips, or if there is a quick way to remove all markers from all the clips?
    Thank you,
    cinematographer//
    8/16mm>2K.transfers
  • Ola Haldor voll
    December 2, 2011 at 4:18 pm
    Quickest way is to jump to each clip, jump to the keyframe and delete it.
  • Sascha Haber
    December 2, 2011 at 6:20 pm
    There are some markes you cant delete
    On the first fram for example after copying a shot.
    A slice of color…
    DaVinci 8.1.1 OSX 10.7.2
    MacPro 5.1 2×2,4 24GB
    RAID0 8TB
    GTX 470 / GT 120
    Extreme 3D+
    ICA Instructor
    https://www.icolorist.com/Sascha.html
