Activity › Forums › Adobe Premiere Pro › Playback speed while editing?
Posted by Michael Reedy on June 25, 2012 at 3:13 pmI have many hours of footage to go through and I have to watch all of it to add in elements at the correct time. When I was on Sony Vegas I had a tool that let me watch the composition at a high speed without actually changing the speed of the composition. Does Premiere Pro have this tool and if so how can I use it?
Carlos Silva replied 9 years, 7 months ago 7 Members · 7 Replies -
Jon Barrie
June 26, 2012 at 12:20 amYou can use some shortcuts to playback faster than realtime without going so fast you can’t understand the dialog.
Hit play, with either spacebar or L key to being playback.
Hold Shift key down, tap L and keep tapping L until the playback speed is where you have optimal clarity and speed.(Recall how many times you tapped).
If you go too far tap J to pull back a speed.
You could go the other way which may be more efficient:
Tap L twice to go into 2x speed. Which will most likely be too fast.
Hold Shift and tap J a couple times to pull down the speed.Hope this helps.
Cheers JB
Jon Barrie
Adobe Video Solutions Consultant ANZ
Jon’s YouTube Tutorial Page
follow Jon with twitter -
Michael Reedy
June 26, 2012 at 5:12 amThat is EXACTLY what I was looking for! This will speed up the process for me a lot! Thank you fine sir!
Adrian Goleby
February 4, 2014 at 3:38 amThanks so much! this helped me out as well!
Switching from Avid to Premiere is interesting haha.
Nicola Hammond
June 8, 2014 at 12:04 pmThank you SO much – I don’t know how people can edit in real time and why this information is so hidden in PP help and shortcuts. So a very big thank you!
John Shulters
March 11, 2016 at 9:07 pmHi Jon,
Was doing some quick Googling to find out why Premiere was all of a sudden playing back my timeline at some wonky fast speed. I must have hit keys accidentally to bump it into a faster playback mode.
I can use your tips with J/K/L to change the playback rate, but how do I just get it back to the default. All my Premiere projects are now playing at a choppy incorrect speed and no amount of J/K/L-ing gets it back to normal.
Thanks so much for your help!
John -
Carlos Silva
January 27, 2017 at 3:58 pmHi. I just added a suggestion to address this issue in MAGIX Vegas PRO forum.
“Speed up/down timeline playback rate preserving pitch”:
https://www.vegascreativesoftware.info/us/forum/suggestion-speed-up-down-timeline-playback-rate-preserving-pitch–105358/If that suggestion (feature request) interest you, join the thread and provide further ideas and comments.
