Activity › Forums › Apple Final Cut Pro Legacy › Playback problems with FCP 5
  • Playback problems with FCP 5
    Posted by Mark Jackson on February 14, 2006 at 9:11 pm
    I have been experiencing some playback problems with my FCP 5. When I play a sequence in the timeline, it randomly hesitates and then it plays fine.
    Can anyone please help me with this problem?
    I’m running Final Cut Pro 5 on a Mac G5 with Dual 2GHZ and 1.5 DDR SDRAM.
    Enzo Tedeschi replied 20 years, 7 months ago 3 Members · 4 Replies
  • Shane Ross
    February 15, 2006 at 6:14 am
    Where does the media reside? On a separate drive than the Operating System? Hope so.
    Does this happen in the same place, or randomly?
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Mark Jackson
    February 15, 2006 at 2:57 pm
    The media is locate on an external Lacie firewire drive. No. It doesn’t happen on the same frame or spot in the timeline. It’s random.
    If I export the sequence as a quicktime movie and reimport into FCP, do you think I would have any problems with playback in the timeline?
  • Shane Ross
    February 15, 2006 at 7:34 pm
    Try it. That is a good work around that I myself use.
    Shane
    Alokut Productions
    http://www.lfhd.net
  • Enzo Tedeschi
    February 16, 2006 at 8:58 pm
    When you say random – does it pause momentarily mid-playback, or is it slow to respond to your play command initially? Those external drives can sometimes spin down to save power if they are idle for a short while, needing time to spin up again when you hit play. This causes a delay between pressing play and the timeline responding. Just a thought.
    Enzo Tedeschi
    ____________________________
    Editor
    Sydney, Australia
