Activity Forums Apple Final Cut Pro Legacy Playback problems
  • Playback problems
    Posted by Justin Badger on December 15, 2006 at 11:38 am
    Thank you for a great forum. To date it has been invaluable.
    Here’s my problem:
    I have material captured from PAL digibeta via the Kona card using the PAL DV codec. Uninterrupted playback of 2 x 1 hour cut sequences is impossible. The Sequence, Capture & Video Playback presets are all set for 625 25 DV. Everything is rendered. Stops occur with a dialogue box saying the disks are too slow.
    I have done the following:
    1. Only one open sequence
    2. Tried both Unlimited RT & Safe RT
    3. Set the sequence to playback at each of the quality settings (including Low)
    4. Mixed down the audio
    5. Moved the media from an un-striped drive to a striped one (both 7200rpm serial ATA.)
    None of the above is allowing either of the sequences to play from start to finish. The stops are frequent.
    I was under the impression that this system would have no problems playing back DVCPRO HD and uncompressed 10-bit PAL. So you can imagine my surprise when it appears not to be able to manage PAL DV. I can’t believe 7200rpm Serial ATA drives really are too slow for DV.
    What have I missed? Any suggestions greatfully received.
    Justin
    Dual 2.3 GHz Power PC G5
    3GB DDR SDRAM
    Mac OS X 10.4.8
    FCP 5.1.2
    NVIDIA GeForce 6800 Ultra DDL (Slot 1)
    Sonnet Tempo-X eSATA 4+4 (Slot 3) Driver: 2.0.4b1
    G-Tech 2x500GB G-SATA 7200rpm drive (striped)
    Justin Badger replied 19 years, 9 months ago 3 Members · 4 Replies
  • Jerry Hofmann
    December 15, 2006 at 3:43 pm
    Have you performed a mixdown of the audio? Command is in the Sequence render only menu. Try that.
    Jerry
    Apple Certified Trainer
    Author: “Jerry Hofmann on Final Cut Pro 4” Click here
    Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D
  • Justin Badger
    December 15, 2006 at 5:06 pm
    Thanks Jerry, but have already done that (No.4 in my list) with no noticeable effect.
    Justin
  • Jhaughey
    December 15, 2006 at 5:17 pm
    Try turning off ‘mirror on desktop’ in the audio video settings… failing that dump the files in the render manager and re-render… might help….
    Joe Haughey
    https://www.pogofilms.com
  • Justin Badger
    December 18, 2006 at 5:52 pm
    “Try turning off ‘mirror on desktop’ in the audio video settings… failing that dump the files in the render manager and re-render… might help…”
    No luck with either of these. Anybody got further ideas?
