Activity Forums Apple Final Cut Pro Legacy Playback of 1 hour documentary
  • Playback of 1 hour documentary
    Posted by Chris Walsh on July 21, 2010 at 2:51 pm
    I recently produced a 1 hour documentary. I am having a premiere for about 300 people tomorrow night. The film was shot in HDV, and I exported it as a self contained movie which is about 10.5 Gigs.
    Is it a bad idea to play the movie back from this file, out of my MacBook Pro? Is that a risky thing to do? What would you do if you were me (besides not shooting in HDV in the first place!)?
    Chris Walsh
    Michael Gissing replied 16 years, 2 months ago 4 Members · 4 Replies
  • Jerry Hofmann
    July 21, 2010 at 5:13 pm
    Put it on an firewire drive, and it should play OK.
    Jerry
    Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
    8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX Cinema Displays
  • Brian Miller
    July 21, 2010 at 6:57 pm
    my first question: how are you connecting to the screen, through DVI? Is the screen going to be able to display your file at it’s full native resolution (1440×1080 for HDV)? if not just burn it to DVD…
  • Chris Walsh
    July 21, 2010 at 8:06 pm
    Thanks, Jerry. I’m honored to have you answer my question. I loaded a self contained version onto my laptop and it played well from there, although I’m sure you have a reason to play it off a separate hard drive. I also have a blu-ray version of it, but I won’t have it until a few hours before the event so I might not have time to go through the whole thing!
    Thanks again.
  • Michael Gissing
    July 21, 2010 at 10:03 pm
    HDV is the same data rate as DV so easy to play of a firewire drive. Do a test to make sure the media player and projector can stretch the 1440 x 1080 out to 1920 x 1080.
    The file you are making for the blu ray disk can also be played directly as it will be either H264 or mpeg2 1920 x 1080.
