Activity Forums Apple Motion Playback Jumpy
  • Playback Jumpy
    Posted by Michael Ford on September 17, 2009 at 11:14 pm
    Hi, at first when i started using Motion everything would play fine. now i am finding it jumpy when i play anything back but the audio playback is fine. whether it be a simple text in and out or a video for adding text overlays. everything is fine if i export it though. i dont want to export everything every time i want to play it back. is there a setting i need to change?
    Stephen Smith replied 17 years ago 3 Members · 7 Replies
  • 7 Replies
  • Zak Peric
    September 17, 2009 at 11:38 pm
    delete the preferences of motion and restart it. see if this helps.
    thy are in home folder/library/preferences/ look for something like com.apple.motion.plist
    Also reset you Parameter Ram on your mac.
  • Michael Ford
    September 18, 2009 at 12:17 am
    unfortunatly nothing has changed. Trashed the Pref’s and reset PRAM. but nothing has improved.
  • Zak Peric
    September 18, 2009 at 12:20 am
    What computer do you have. And how much ram and what graphic card please.
  • Michael Ford
    September 18, 2009 at 12:30 am
    MacPro – QuadCore, 3GB RAM, NVIDIA GeForce GT 120
  • Zak Peric
    September 18, 2009 at 12:37 am
    looks like it is going ot be difficult to pin point the problem. If I was you I would first fix permissions (at least few times) restart the computer. And if this does not help I would reinstall motion from a original disk. This should solve you problem I hope.
  • Michael Ford
    September 18, 2009 at 12:41 am
    ok. thanks for the help, unfortunatly its getting really late and i have work in 5 hours and need sleep. i will try again tomorrow (later today) and see what happens, thank you.
  • Stephen Smith
    September 18, 2009 at 6:53 pm
    Michael, here is a link to an article that I think will help. Zak already covered some of it.
    https://support.apple.com/kb/HT1885
    Stephen Smith
    Lone Peak Productions
    Check out my Motion Tutorials
