Activity Forums Apple Final Cut Pro Legacy Playback issues in Final Cut Pro 7
  • Playback issues in Final Cut Pro 7
    Posted by Robert Jessurum on February 20, 2014 at 2:14 am
    Good afternoon everyone!!
    I´ll cut to the chase: I´m currently working with a bunch of MP4 files in H.264 codec. I´m having a ton of issues with this material (my client doesn´t want to change it, for whatever reason): dropped frames, slow render and an unsynched export file (no lipsync).
    I have a few questions about this:
    -How can I improve the framerate in playback? (can´t find the Unlimiteed RT option)
    -How can I fix the lipsync in the export .MOV file? (the Timeline sequence is fine in that regard, I must add)
    Thanks in advance.
    Neil Patience replied 12 years, 7 months ago 2 Members · 1 Reply
  • Neil Patience
    February 20, 2014 at 2:46 am
    Hi Robert,
    Pretty much everything you describe is down to trying to edit MP4 H264 files in FCP7. A quick search here will show you this is a no no.
    Either you need to transcode your files to ProRes or use something else to edit if your client won’t let you change them.
    But otherwise these issues will dog you throughout your edit.
    best wishes
    Neil
    http://www.patience.tv
    8 Core MacPro, Kona 3, Tangent Wave, Mackie Universal Symphony 6.5 or MC V 7 with Symphony option. FCP7, Color, Media creation and conversion. Adobe Encore DVD creation and authoring.
    i7 2.7 Gig MBP (non retina) 16Gigs Ram Blackmagic Monitor Mini Symphony 6.5 or MC v7 with Symphony option FCP7
    7TB raid 5 fibre storage.
