Activity › Forums › Apple Final Cut Pro Legacy › Playback issues.
  • Playback issues.
    Posted by Garrett Shore on October 30, 2005 at 5:24 pm
    To all who’ve seen it:
    Ive never had playback issues until recently. Of course, i checked that my playback window was fit to screen or smaller and this isn’t the problem. When i hit the space bar, i get audio playback, but the image is a freeze frame, like the computer is chocking on the video. When i hit pace bar again, it stops on the latest frame. It is really annoying and i can’t stop it. Only sometimes can i actually get playback.
    everything is rendered too.
    I’m using DVCpro HD 720p59.94 with an AJA kona 2 on a dual 2.0 G5 with 2.5 GB RAM with OS 10.3.9
    i cannot figure out why i cannot get video to start playing. However, if i preroll with my playback arrow riding in empty space for a good 3 seconds, when it gets to the video, it plays fine.
    anyone know whats causing this?
    garrett
    Rob Forsythe replied 20 years, 11 months ago 2 Members · 2 Replies
  • Rob Forsythe
    October 30, 2005 at 7:02 pm
    This list contains virtually everything to try to enable:
    a. External Monitor VIDEO and AUDIO via FireWire & DV deck or camcorder.
    b. Viewing in the Canvas window on the computer screen.
    c. Being able to record on the external FW DV deck or camcorder.
    d. Being able to capture from a FW device.
    If working this list doesn’t cure the problem… you may have a PROBLEM!
    Try things in this order until you find the “cure”:
    1. Make sure you have only ONE (1) FireWire deck, camcorder, DV capture “card”, or D-to-A converter or video device attached to the computer at a time. Any more than one DV device can cause loss of signal and control.
    2. Make sure you have View (Menu) > External Video> All Frames set.
    (If the ALL FRAMES option is grayed-out… jump to step 6 below and continue.)
    3. Make SURE your Canvas window (right window) in FCP is set to “Fit to Window”… AND that it has not been “pushed off” the edge of the computer screen.
    4. Make sure your CANVAS View Menu (Box Icon with broken sides) is checked on Image or Image+Wireframe… NOT just Wireframe.
    5. Make sure your CANVAS View Menu is checked on RGB… NOT just Alpha.
    6. Make sure your Final Cut Pro (menu) > Easy Setup… is set for DV-NTSC (or DV-PAL, if that’s where you are).
    7. Some camcorders/decks work better under “FW (NTSC/PAL)” -or- “FW (NTSC/PAL) Basic” control (in the capture settings). Try either setting to see which works best for your device.
    8. Make sure your Final Cut Pro (menu) > Audio/Video Settings > A/V Devices (tab) > Mirror on Desktop > must be CHECKED. (If not, playing video will not appear in the Canvas.)
    9. Make sure the “Log and Capture” Window is CLOSED and not just “hidden” behind other windows.
    10. Turn off the power to the Camera/Deck/Converter Box, then turn it back ON.
    11. Make sure the camera is in VTR mode… or the deck is in DV (DV, iLink, or FW) input.
    12. On a Sony camcorder or deck, make sure the menu setting “A/V > DV Out” is set to OFF.
    13. Re-check that your FW cable is well-connected at both ends (or try a new cable).
    14. Important: Quit FCP, then Restart FCP.
    15. Now again, make sure you have View > External Video > ALL FRAMES set…
    If it still does not work. “Trash” the FCP Preferences on the Mac
    https://www.kenstone.net/fcp_homepage/trashing_fcp_prefs.html
    “FCP Rescue” is a free Apple Script that will Trash the Preferences.
    It will also restore your user settings afterwards.
    Download:
    https://www.macupdate.com/info.php/id/14729
    >Then, start again at my “step 1” above.
  • Rob Forsythe
    October 30, 2005 at 7:03 pm
    And, you should always MIXDOWN your audio before you play your sequence.
    First, SELECT ALL of your audio tracks (highlight them) on the timeline, then:
    Sequence Menu > Render Only > Mixdown.
    This can help with all kinds of “sticking” playback problems, audio and/or video.
