Activity Forums Apple Final Cut Pro Legacy Playback Issues
  • Playback Issues
    Posted by Joe Mcarthur on December 16, 2007 at 4:04 pm
    captured pro res HQ . . . image is sharp in timeline. . . when i hit spacebar to playback the clip is blurred . . when i stop it goes sharp again . . tried capturing uncompressed 8bit, same issue . . . is there a setting i can change to fix this . . . it seems it is previewing in low rez
    David Battistella replied 18 years, 9 months ago 3 Members · 2 Replies
  • Tom Meegan
    December 16, 2007 at 6:51 pm
    Sounds like the sequence needs to be rendered, which means that the sequence settings and the clip settings don’t match.
    Select the clip and hit Command – 9.
    Make notes.
    Select the sequence and hit Command – Zero.
    Compare and contrast.
    Alternatively choose the appropriate easy set up for your footage.
    Also
  • David Battistella
    December 18, 2007 at 9:07 pm
    Set RT setting to SAFE and playback quality should be HIGH not DYNAMIC, same with framerates, etc.
    David
    Peace and Love 🙂
    Read my Blog
    https://blogs.creativecow.net/DavidBattistella
