Activity › Forums › Apple Final Cut Pro Legacy › Playback Issue-ProRes Proxy
Posted by Mike Kahn on January 11, 2011 at 4:09 pmI have a client cutting a feature that was captured at ProRes Proxy for the offline edit. The media is on an Avid Unity through fibre connection. The unity is an accepted and approved raid and all the drivers are correct.
Over the last few weeks, the editor has been experiencing an issue where he will be cutting and as he plays back the sequence, it begins to stutter. The stutter appears to be quickly viewing the previous cut (cut A) as well as the cut that should be played back (cut B), ABABABABA. If I stop playback and go back and hit play, it will continue to happen.
It appears to be random, but I believe it happens mostly around multiclip cuts. The stutter can be seen both in the canvas window and the external monitor. I can collapse the multiclip and it goes away, but then it comes back on a different clip down the line.
I have trashed permissions, reseated all cards, updated Kona 3 driver…everything short of reinstalling the OS.
This is a Mac Pro, OS 10.6.5, FCP 7.0.3, Kona 3
Any suggestions are appreciated.
Mike
Mike Kahn replied 15 years, 8 months ago 2 Members · 4 Replies -
Jerry Hofmann
January 12, 2011 at 2:04 pmThe likely suspect here is the Unity system… I’ll wager that if the media was local on local disks, the problem would go away.
Jerry
Apple Certified Trainer, Producer, Writer, Director Editor, Gun for Hire and other things. I ski. My Blog: https://blogs.creativecow.net/Jerry-Hofmann
Current DVD:
https://store.creativecow.net/p/81/jerry_hofmanns_final_cut_system_setup8-Core 3.0 Intel Mac Pro, Dual 2 gig G5, AJA Kona SD, AJA Kona 2, Huge Systems Array UL3D, AJA Io HD, 17″ MBP, Matrox MXO2 with MAX – Cinema Displays I have a 22″ that I paid 4k for still working. G4 with Kona SD card, and SCSI card.
Mike Kahn
January 12, 2011 at 3:50 pmSince posting yesterday, I’ve swapped the HD and CPU. Within an hour of that, my editor crashed again. The problem as far as I can tell comes down to Unity, project corruption, and/or media corruption.
The fact that it is seemingly random, I’m thinking that media corruption is not a problem. If it was media, it would crash at the same place every time.
What do you guys do to fix project corruption? I have made new projects, copied from old to new and saved. Also, I’ve made new sequences and copied from old to new. Anything else that people have done to fix corruptions?
Mike
Mike Kahn
January 12, 2011 at 4:19 pmI have a crash report if anyone can make heads or tails of it:
Process: Final Cut Pro [461]
Path: /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
Identifier: com.apple.FinalCutPro
Version: 7.0.3 (7.0.3)
Build Info: FCPApp-1008261348~8
Code Type: X86 (Native)
Parent Process: launchd [128]PlugIn Path: /Library/QuickTime/AJAVideoOutput.component/Contents/MacOS/AJAVideoOutput
PlugIn Identifier: com.aja.kona.videooutput
PlugIn Version: 8.0 (8.0)Date/Time: 2011-01-12 10:36:43.059 -0500
OS Version: Mac OS X 10.6.5 (10H574)
Report Version: 6Exception Type: EXC_BAD_ACCESS (SIGBUS)
Exception Codes: KERN_PROTECTION_FAILURE at 0x0000000000000000
Crashed Thread: 42Thread 0: Dispatch queue: com.apple.main-thread
0 libSystem.B.dylib 0x968480a6 __semwait_signal + 10
1 libSystem.B.dylib 0x96873ee5 nanosleep$UNIX2003 + 188
2 libSystem.B.dylib 0x96873e23 usleep$UNIX2003 + 61
3 com.aja.kona.videooutput 0x1c31633b APW::VO::Alpine::VideoOutput::BandDecompress(APW::Alpine::DecompressRecord*) + 4465
4 com.aja.kona.videooutputcodec 0x16c059d1 myCodecBandDecompress(CodecGlobals*, CodecDecompressParams*) + 4946
5 …ple.CoreServices.CarbonCore 0x982f0054 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
6 com.aja.kona.videooutputcodec 0x16c06523 myCodecComponentDispatch + 148
7 …ple.CoreServices.CarbonCore 0x982e87c9 CallComponentDispatch + 29
8 com.apple.QuickTime 0x9970d2b3 ImageCodecBandDecompress + 43
9 com.apple.QuickTime 0x996fb3ba DoBandedDecompress + 17565
10 com.apple.QuickTime 0x996f6d21 ICMAction + 1177
11 com.apple.QuickTime 0x996f5930 ICMDeviceLoop + 546
12 com.apple.QuickTime 0x996fe8be DecompressSequenceFrameWhen + 714
13 com.apple.FinalCutPro 0x0043aae9 VideoOutput::PostOutput(Output*, long long, BufferIndexEnum, bool, float) + 2631
14 com.apple.FinalCutPro 0x0042c872 FCPMediaHandler::Idle(long, long, long*, TimeRecord*) + 1848
15 com.apple.FinalCutPro 0x0042d495 FCPMHIdle(FCPMediaHandler*, long, long, long*, TimeRecord*) + 45
16 …ple.CoreServices.CarbonCore 0x982fb309 callComponentStorage_44444 + 49
17 …ple.CoreServices.CarbonCore 0x982f0054 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
18 com.apple.FinalCutPro 0x00426221 FCPMHDispatch(ComponentParameters*, char**) + 59
19 …ple.CoreServices.CarbonCore 0x982e87c9 CallComponentDispatch + 29
20 …ickTimeComponents.component 0x98003b87 MediaIdle + 61
21 …ickTimeComponents.component 0x9788014a doGenericIdle + 2991
22 …ickTimeComponents.component 0x97881f7f GenericMoviesTask + 357
23 …ple.CoreServices.CarbonCore 0x982fb309 callComponentStorage_44444 + 49
24 …ple.CoreServices.CarbonCore 0x982f0054 CallComponentFunctionCommonWithStorage(char**, ComponentParameters*, long (*)(), unsigned long) + 54
25 …ickTimeComponents.component 0x978816d2 GenericComponentDispatch + 182
26 com.apple.FinalCutPro 0x0042623d FCPMHDispatch(ComponentParameters*, char**) + 87
27 …ple.CoreServices.CarbonCore 0x982e87c9 CallComponentDispatch + 29
28 com.apple.QuickTime 0x997509aa MediaMoviesTask + 61
29 com.apple.QuickTime 0x9974f746 TaskMovie_priv + 4808
30 com.apple.QuickTime 0x99762578 MoviesTask_priv + 101
31 com.apple.FinalCutPro 0x001ba928 DoMoviesTask(KGPlayerRec*) + 2388
32 com.apple.FinalCutPro 0x001cd651 DisplayMovie(KGPlayerRec*) + 2201
33 com.apple.FinalCutPro 0x001d23ff pKGPlayerGoto(KGPlayerRec*, double, long, unsigned char) + 509
34 com.apple.FinalCutPro 0x001bb173 PlayerNotify(long, long, KGDictInt*, void*) + 149
35 com.apple.FinalCutPro 0x00113d97 DispatchNotificationsHelp(void**, KGDictInt*, long, long, unsigned char) + 157
36 com.apple.FinalCutPro 0x0011408b DispatchNotifications + 273
37 com.apple.FinalCutPro 0x0001e4cb HashInsertFull(HashDict*, char*, long, unsigned char, void*, KGTypeValueContainer*, void**, unsigned char, KGDictNotifyHolder**, KGDictUndoMethod, long, unsigned char, unsigned long) + 1083
38 com.apple.FinalCutPro 0x0001fb7d DispatchHashDict(KGDictSelector, KGDictInt*, KGDictParams*) + 221
39 com.apple.FinalCutPro 0x00114de6 pKGDictPut1(KGDictInt*, void*, long, char*) + 88
40 com.apple.FinalCutPro 0x00107498 pKGRulerMessage(long, long, KGDictInt*, KGViewRecord*) + 15276
41 com.apple.FinalCutPro 0x002a8031 PPassMouseEvent(KGPanelRecord*, KGDictInt*, long) + 1537
42 com.apple.FinalCutPro 0x002b131a pKGPanelMessage(long, long, KGDictInt*, KGViewRecord*) + 112
43 com.apple.FinalCutPro 0x0025e872 ServicesPanelsMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 120
44 com.apple.FinalCutPro 0x0025fd1c TimelineMessageProc(long, long, KGDictInt*, KGPanelRecord*) + 110
45 com.apple.FinalCutPro 0x002a7781 pKGPanelWindowProc(long, long, KGDictInt*, void*) + 53
46 com.apple.FinalCutPro 0x002bd5a3 pKGSendWindowMessage(KGWindowRec*, long, long, KGDictInt*) + 91
47 com.apple.FinalCutPro 0x001573fb HandleMouseDown(OpaqueEventRef*) + 2525
48 com.apple.FinalCutPro 0x00157e4d DoEvent(OpaqueEventRef*, KGDictInt*) + 729
49 com.apple.FinalCutPro 0x00414501 Events(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 67
50 com.apple.HIToolbox 0x98c13f2f DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1567
51 com.apple.HIToolbox 0x98c131f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
52 com.apple.HIToolbox 0x98c359bb SendEventToEventTarget + 52
53 com.apple.HIToolbox 0x98c474db ToolboxEventDispatcherHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1257
54 com.apple.HIToolbox 0x98c14380 DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 2672
55 com.apple.HIToolbox 0x98c131f6 SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 411
56 com.apple.HIToolbox 0x98c359bb SendEventToEventTarget + 52
57 com.apple.HIToolbox 0x98dbecc3 ToolboxEventDispatcher + 86
58 com.apple.HIToolbox 0x98dbedfb RunApplicationEventLoop + 243
59 com.apple.FinalCutPro 0x001539d1 KGMainEvent(void*) + 51
60 com.apple.FinalCutPro 0x002c1278 main + 54
61 com.apple.FinalCutPro 0x00002d5b _start + 209
62 com.apple.FinalCutPro 0x00002c89 start + 41Thread 1: Dispatch queue: com.apple.libdispatch-manager
0 libSystem.B.dylib 0x96840982 kevent + 10
1 libSystem.B.dylib 0x9684109c _dispatch_mgr_invoke + 215
2 libSystem.B.dylib 0x96840559 _dispatch_queue_invoke + 163
3 libSystem.B.dylib 0x968402fe _dispatch_worker_thread2 + 240
4 libSystem.B.dylib 0x9683fd81 _pthread_wqthread + 390
5 libSystem.B.dylib 0x9683fbc6 start_wqthread + 30Thread 2: com.apple.CFSocket.private
0 libSystem.B.dylib 0x968390c6 select$DARWIN_EXTSN + 10
1 com.apple.CoreFoundation 0x913d4c83 __CFSocketManager + 1091
2 libSystem.B.dylib 0x9684785d _pthread_start + 345
3 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 3:
0 libSystem.B.dylib 0x9681a20e mach_wait_until + 10
1 libSystem.B.dylib 0x968a1819 nanosleep + 345
2 libSystem.B.dylib 0x968a16ba usleep + 61
3 com.apple.FinalCutPro 0x00429208 DisplayQueue::Run() + 914
4 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
5 libSystem.B.dylib 0x9684785d _pthread_start + 345
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 4:
0 libSystem.B.dylib 0x9681a142 semaphore_wait_signal_trap + 10
1 libSystem.B.dylib 0x96847cfc _pthread_cond_wait + 1089
2 libSystem.B.dylib 0x9689046f pthread_cond_wait + 48
3 com.apple.FinalCutPro 0x0043f42b Synchronizable::Wait() + 53
4 com.apple.FinalCutPro 0x004e67c3 WorkUnitPerformer::Run() + 55
5 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
6 libSystem.B.dylib 0x9684785d _pthread_start + 345
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 5:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 6:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 7:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 8:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 9:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 10:
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 11:
0 libSystem.B.dylib 0x9681a0fa mach_msg_trap + 10
1 libSystem.B.dylib 0x9681a867 mach_msg + 68
2 com.apple.CoreFoundation 0x9139537f __CFRunLoopRun + 2079
3 com.apple.CoreFoundation 0x91394464 CFRunLoopRunSpecific + 452
4 com.apple.CoreFoundation 0x91394291 CFRunLoopRunInMode + 97
5 ….CoreMediaIOServicesPrivate 0x010e69b3 MIO::DAL::RunLoop::OwnThread(void*) + 157
6 ….CoreMediaIOServicesPrivate 0x010e8824 CAPThread::Entry(CAPThread*) + 96
7 libSystem.B.dylib 0x9684785d _pthread_start + 345
8 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 12:
4 com.apple.CoreFoundation 0x9139a3a4 CFRunLoopRun + 84
5 com.apple.qmaster.do 0x1eb2e460 swamp::CRAdReceiver2::ReceivingThread::runOnce() + 234
6 com.apple.AECore 0x1e51b022 aecore::CThread::runThread() + 34
7 com.apple.AECore 0x1e518fb9 threadProc(void*) + 17
8 libSystem.B.dylib 0x9684785d _pthread_start + 345
9 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 13:
1 com.apple.AECore 0x1e51b067 aecore::CThread::runThread() + 103
2 com.apple.AECore 0x1e518fb9 threadProc(void*) + 17
3 libSystem.B.dylib 0x9684785d _pthread_start + 345
4 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 14:
0 libSystem.B.dylib 0x9681a15a semaphore_timedwait_signal_trap + 10
1 libSystem.B.dylib 0x96847ce5 _pthread_cond_wait + 1066
2 libSystem.B.dylib 0x96876ac8 pthread_cond_timedwait_relative_np + 47
3 …ple.CoreServices.CarbonCore 0x982c7ecd TSWaitOnConditionTimedRelative + 242
4 …ple.CoreServices.CarbonCore 0x982c7c0b TSWaitOnSemaphoreCommon + 511
5 …ickTimeComponents.component 0x97815d49 ReadSchedulerThreadEntryPoint + 4698
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 15:
3 com.apple.AppleProResCodec 0x15cf940b IcpDecompressorComponentDispatch + 1771
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 16:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 17:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 18:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 19:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 20:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 21:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 22:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 23:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 24:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 25:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 26:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 27:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 28:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 29:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 30:
4 libSystem.B.dylib 0x9684785d _pthread_start + 345Thread 31:
5 com.apple.DesktopServices 0x90a58e51 TSystemNotificationTask::SystemNotificationTaskProc(void*) + 643
6 …ple.CoreServices.CarbonCore 0x982a785a PrivateMPEntryPoint + 68
8 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 32:
4 com.apple.FinalCutPro 0x00090525 SyncMetaDataTask::GetNextEvent() + 81
5 com.apple.FinalCutPro 0x00091453 SyncMetaDataTask::Run() + 39
6 com.apple.FinalCutPro 0x0046b49a Thread::RunHelper(void*) + 20
8 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 33:
1 libSystem.B.dylib 0x96847d62 _pthread_cond_wait + 1191
2 libSystem.B.dylib 0x968499f8 pthread_cond_wait$UNIX2003 + 73
3 com.apple.vImage 0x96a8850c vImageQueue_DequeueJob + 44
4 com.apple.vImage 0x96a8860c vImageWorkerThreadFunc + 124
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 34:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 35:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 36:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 37:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 38:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 39:
6 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 40:
0 libSystem.B.dylib 0x9683fa12 __workq_kernreturn + 10
1 libSystem.B.dylib 0x9683ffa8 _pthread_wqthread + 941
2 libSystem.B.dylib 0x9683fbc6 start_wqthread + 30Thread 41:
5 …ple.CoreServices.CarbonCore 0x98322732 AIOFileThread(void*) + 1127
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 42 Crashed:
0 libSystem.B.dylib 0xffff0820 __memcpy + 128
1 com.aja.kona.videooutput 0x1c32746e MoveFrame(char*, unsigned long, unsigned long, unsigned long, char*, unsigned long, unsigned long, unsigned long, unsigned long) + 140
2 com.aja.kona.videooutput 0x1c337ffe CFormatConverter::CConvertFrame(char*, unsigned long, unsigned long, unsigned long, char*, unsigned long, unsigned long, unsigned long) + 6684
3 com.aja.kona.videooutput 0x1c312ac2 APW::VO::Alpine::VideoOutput::CopyDrpToFrame(APW::Alpine::DecompressRecord*, APW::Mux::Alpine::FrameOut*) + 2778
4 com.aja.kona.videooutput 0x1c314861 APW::VO::Alpine::VideoOutput::FrameNew(APW::Mux::Alpine::FrameOut*) + 63
5 com.aja.kona.muxer 0x1e446c1b APW::Mux::Alpine::Muxer::DoFrameCallbacks(unsigned int, void*) + 435
6 com.aja.kona.muxer 0x1e44650b APW::Mux::Alpine::Muxer::RunPlaybackAutoCirculateThread() + 519
7 com.aja.kona.muxer 0x1e44501b APW::Mux::Alpine::Muxer::Run(int) + 107
8 com.aja.kona.muxer 0x1e40f129 APW::PTA::Thread::RunHelper(void*) + 27
9 libSystem.B.dylib 0x9684785d _pthread_start + 345
10 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 43:
2 com.apple.framework.IOKit 0x91b1a46d io_connect_method + 574
3 com.apple.framework.IOKit 0x91acabae IOConnectCallMethod + 318
4 com.apple.framework.IOKit 0x91acadf6 IOConnectCallScalarMethod + 84
5 com.aja.kona.muxer 0x1e41a5c8 CNTV2MacDriverInterface::WaitForInterrupt(_INTERRUPT_ENUMS_, unsigned int) + 148
6 com.aja.kona.muxer 0x1e42ba58 CNTV2Card::WaitForFieldID(NTV2FieldID) + 90
7 com.aja.kona.muxer 0x1e448922 APW::Mux::Alpine::Muxer::RunPlaybackVbiThread() + 1884
8 com.aja.kona.muxer 0x1e445003 APW::Mux::Alpine::Muxer::Run(int) + 83
9 com.aja.kona.muxer 0x1e40f129 APW::PTA::Thread::RunHelper(void*) + 27
10 libSystem.B.dylib 0x9684785d _pthread_start + 345
11 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 44:
5 …ple.CoreServices.CarbonCore 0x982ebe33 TimerThread + 97
7 libSystem.B.dylib 0x968476e2 thread_start + 34Thread 45:
2 libSystem.B.dylib 0x9683fbc6 start_wqthread + 30Thread 42 crashed with X86 Thread State (32-bit):
eax: 0xffff07a0 ebx: 0x00001400 ecx: 0x00000000 edx: 0xffaba000
edi: 0x4a7d4000 esi: 0x00546000 ebp: 0xb9681a18 esp: 0xb9681a10
ss: 0x0000001f efl: 0x00010246 eip: 0xffff0820 cs: 0x00000017
ds: 0x0000001f es: 0x0000001f fs: 0x0000001f gs: 0x00000037
cr2: 0x00000000Binary Images:
0x1000 – 0x870ffc com.apple.FinalCutPro 7.0.3 (7.0.3) <41B8A263-80F3-BCC3-FE28-82DE571687A1> /Applications/Final Cut Pro.app/Contents/MacOS/Final Cut Pro
0xc2e000 – 0xc31ff7 +KGCore ??? (???) /Applications/Final Cut Pro.app/Contents/Frameworks/KGCore.framework/Versions/A/KGCore
0xc39000 – 0xc39ff7 com.apple.iokit.dvcomponentglue 1.9.9 (1.9.9) <2BA05DB9-D847-CBC7-42D6-A9D96D7E1ED2> /System/Library/Frameworks/DVComponentGlue.framework/Versions/A/DVComponentGlue
0xc3d000 – 0xc4cfff com.apple.AERegistration 1.2 (77) <5D18C47F-6F9E-0C4C-8875-24A14A97186D> /Applications/Final Cut Pro.app/Contents/Frameworks/AERegistration.framework/Versions/A/AERegistration
0xc60000 – 0xc67fff com.apple.AEProfiling 1.2 (22) <43A46C32-8E13-82DD-8AF1-2A40690BF810> /Applications/Final Cut Pro.app/Contents/Frameworks/AEProfiling.framework/Versions/A/AEProfiling
0xc71000 – 0xe97fe7 com.apple.prokit 6.0.1 (1176) <7F8A965A-3159-4B0C-D52C-0F51854FB3FD> /System/Library/PrivateFrameworks/ProKit.framework/Versions/A/ProKit
0xf9b000 – 0x100dfef com.apple.ProFX 1.2.3 (1.2.3) <06B47AC3-9449-A6F0-E189-09D4D1E29A5A> /Library/Application Support/ProApps/SharedA/Frameworks/ProFX.framework/Versions/A/ProFX
0x102f000 – 0x108bffb com.apple.proapps.MIO 1.0.5 (509) <3FE469A6-C937-1E44-F79C-9AAA7C902A92> /Applications/Final Cut Pro.app/Contents/Frameworks/MIO.framework/Versions/A/MIO
0x10c8000 – 0x10d1ff7 com.apple.finalcutstudio.prometadatasupport 0.6 (1.0) /Library/Frameworks/ProMetadataSupport.framework/Versions/A/ProMetadataSupport
0x10d9000 – 0x1113ffb com.apple.CoreMediaIOServicesPrivate 33.0 (1352) /System/Library/PrivateFrameworks/CoreMediaIOServicesPrivate.framework/Versions/A/CoreMediaIOServicesPrivate
0x112f000 – 0x1158ff7 com.apple.CoreMediaPrivate 20.0 (20.0) <29A9848F-2C1C-BDE4-EADC-2A3C71C1DBC4> /System/Library/PrivateFrameworks/CoreMediaPrivate.framework/Versions/A/CoreMediaPrivate
0x116b000 – 0x119eff3 com.apple.FWAVCPrivate 30.46 (46) <25047C2C-FADF-117A-3012-840E8F32628D> /System/Library/PrivateFrameworks/FWAVCPrivate.framework/Versions/A/FWAVCPrivate
0x11b3000 – 0x11d1fef com.apple.XSKey 1.0.0 (52) <71B94F53-15DB-9012-91F2-211F7C2CD790> /Library/Frameworks/XSKey.framework/Versions/A/XSKey
0x11e0000 – 0x1295fe7 libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
0x1484000 – 0x14c4ff7 com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/vmutils
0x14e2000 – 0x14e3ff7 ATSHI.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/ATSHI.dylib
0xcd5a000 – 0xcd62ff7 com.apple.proapps.mrcheckpro 1.4 (398) <400C6D0F-2AC3-F06D-E20C-741BA3D9A558> /Applications/Final Cut Pro.app/Contents/Resources/MRCheckPro.bundle/Contents/MacOS/MRCheckPro
0xcdd5000 – 0xcdd9ff3 com.apple.FinalCutPro.Plugins.AudioGroupsExport 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioGroupsExport.bundle/Contents/MacOS/AudioGroupsExport
0xcdde000 – 0xcddeff7 libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
0xcdf1000 – 0xcdf6fff com.apple.FinalCutPro.Plugins.Cache Manager 7.0.3 (7.0.3) <7E686BFA-2AB3-442B-4203-1D8BA4EA5DA2> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cache Manager.bundle/Contents/MacOS/Cache Manager
0xcff4000 – 0xcff7ffc com.apple.FinalCutPro.Plugins.FinalTouchExport 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FinalTouchExport.bundle/Contents/MacOS/FinalTouchExport
0xf1e4000 – 0xf1eeff9 com.apple.FinalCutPro.Plugins.CTHelper 7.0.3 (7.0.3) <4B1D1B9F-16CB-A86E-E385-B82C12CF7DE9> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/CTHelper.bundle/Contents/MacOS/CTHelper
0xf1f5000 – 0xf1f9fff com.apple.FinalCutPro.Plugins.LayerFileReader 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/LayerFileReader.bundle/Contents/MacOS/LayerFileReader
0xf354000 – 0xf378fe7 GLRendererFloat ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFloat
0xf380000 – 0xf397ff3 com.apple.FinalCutPro.Plugins.AudioMixer 7.0.3 (7.0.3) <3C914C5E-510C-EBF8-2FD9-6450CBE8FD46> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AudioMixer.bundle/Contents/MacOS/AudioMixer
0xf3a2000 – 0xf3a6fff com.apple.FinalCutPro.Plugins.NuggetExport 7.0.3 (7.0.3) <83A2CB39-EA91-DB85-E458-DDA09C4F9793> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/NuggetExport.bundle/Contents/MacOS/NuggetExport
0xfbd1000 – 0xfd49fe7 GLEngine ??? (???) /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
0xfdac000 – 0xfdd6ff7 com.apple.FinalCutPro.Plugins.AfterEffects 7.0.3 (7.0.3) <11BBAC1F-38D0-7A1B-0ECD-821729B3AF1B> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/AfterEffects.bundle/Contents/MacOS/AfterEffects
0xfdde000 – 0xfe2affb com.apple.audio.midi.CoreMIDI 1.7.1 (42) /System/Library/Frameworks/CoreMIDI.framework/Versions/A/CoreMIDI
0xfe4f000 – 0xfe79feb com.apple.proapps.ControlSurfaceSupport 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/ControlSurfaceSupport.framework/Versions/A/ControlSurfaceSupport
0xfe9a000 – 0xff72ff2 com.apple.FinalCutPro.Plugins.Browser 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Browser.bundle/Contents/MacOS/Browser
0xff90000 – 0xffaafff com.apple.FinalCutPro.CinemaTools 5.0 (5.0) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Cinema Tools.bundle/Contents/MacOS/Cinema Tools
0xffb6000 – 0xffdcff7 com.apple.FinalCutPro.Plugins.EditTape 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EditTape.bundle/Contents/MacOS/EditTape
0xffeb000 – 0xfff3fff com.apple.FinalCutPro.Plugins.Effect Builder 7.0.3 (7.0.3) <47BE0505-F602-9535-8684-EAF732016E93> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Effect Builder.bundle/Contents/MacOS/Effect Builder
0xfff8000 – 0xfff9fff com.apple.FinalCutPro.Plugins.Text Window 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Text Window.bundle/Contents/MacOS/Text Window
0x10000000 – 0x10060fef com.apple.proapps.AudioMixEngine 2.0 (68) /Applications/Final Cut Pro.app/Contents/Frameworks/AudioMixEngine.framework/Versions/A/AudioMixEngine
0x145c1000 – 0x149c6fe7 libclh.dylib 3.1.1 C (3.1.1) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
0x149ea000 – 0x14a45ff5 com.apple.FinalCutPro.Plugins.EDL Export 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/EDL Export.bundle/Contents/MacOS/EDL Export
0x14a5a000 – 0x14a65ffe com.apple.FinalCutPro.Plugins.FCPExtPluginSupport 7.0.3 (7.0.3) <41DA2698-9984-6241-130D-AACA55C647B4> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCPExtPluginSupport.bundle/Contents/MacOS/FCPExtPluginSupport
0x14a6e000 – 0x14aa1ff7 com.apple.FinalCutPro.Plugins.FCS Engine 7.0.3 (7.0.3) <1D178B47-1E72-47D8-D52D-EE1590B4F5AA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FCS Engine.bundle/Contents/MacOS/FCS Engine
0x14aab000 – 0x14abcff7 com.apple.FinalCutPro.Plugins.FilterCustomEd 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterCustomEd.bundle/Contents/MacOS/FilterCustomEd
0x14ac2000 – 0x14ad7ffb com.apple.FinalCutPro.Plugins.FilterViewer 7.0.3 (7.0.3) <8DA6D80C-B3A2-B2FF-6F2F-A44122508E27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/FilterViewer.bundle/Contents/MacOS/FilterViewer
0x14add000 – 0x14afbfea com.apple.FinalCutPro.Plugins.Flash 7.0.3 (7.0.3) <2CEAAEE1-4EF6-7180-2CAA-6DDE45E667DB> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Flash.bundle/Contents/MacOS/Flash
0x14b07000 – 0x14b14ffb com.apple.FinalCutPro.Plugins.GenViewer 7.0.3 (7.0.3) <724F50F6-7A13-D6C3-B7CB-63CB23829F27> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/GenViewer.bundle/Contents/MacOS/GenViewer
0x14b1a000 – 0x14b66ff3 com.apple.FinalCutPro.Plugins.Media Manager 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Media Manager.bundle/Contents/MacOS/Media Manager
0x14b70000 – 0x14b82ff0 com.apple.FinalCutPro.Plugins.MolokiniSupport 7.0.3 (7.0.3) <85EAB333-1140-0657-27FF-B21F7DAEB40E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/MolokiniSupport.bundle/Contents/MacOS/MolokiniSupport
0x14b91000 – 0x14ba5fff com.apple.FinalCutPro.Frameworks.MolokiniTranslation 1.0 (1.0) <7A59B9CD-7B44-2258-E79B-FCC5F9CAB309> /Applications/Final Cut Pro.app/Contents/Frameworks/MolokiniTranslation.framework/Versions/A/MolokiniTranslation
0x14bb3000 – 0x14be5ffb com.apple.FinalCutPro.Plugins.Motion Viewer 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Motion Viewer.bundle/Contents/MacOS/Motion Viewer
0x14bf6000 – 0x14c11ff3 com.apple.FinalCutPro.Plugins.Movie Analyzer 7.0.3 (7.0.3) <82EA8688-294B-3739-E719-09275DD966A7> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Analyzer.bundle/Contents/MacOS/Movie Analyzer
0x14c20000 – 0x14c36ffb com.apple.FinalCutPro.Plugins.Movie Viewer 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Movie Viewer.bundle/Contents/MacOS/Movie Viewer
0x14c42000 – 0x14cfbfe7 com.apple.FinalCutPro.Plugins.OMF Audio Export 7.0.3 (7.0.3) <1515F152-5847-223C-E5FE-CA894EDF121C> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/OMF Audio Export.bundle/Contents/MacOS/OMF Audio Export
0x14d0e000 – 0x14d16ffb com.apple.FinalCutPro.Plugins.Perf Analyzer 7.0.3 (7.0.3) <1E04DC98-638A-CB1E-C04E-3B0C0E3CD199> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Perf Analyzer.bundle/Contents/MacOS/Perf Analyzer
0x14d1b000 – 0x14d30ffb com.apple.FinalCutPro.Plugins.ProAppsIntegration 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/ProAppsIntegration.bundle/Contents/MacOS/ProAppsIntegration
0x14d40000 – 0x14d4dff7 com.apple.FinalCutPro.Plugins.Pulldown Support 7.0.3 (7.0.3) <555A8A21-3312-5CA8-FDA3-433F997DA91E> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Pulldown Support.bundle/Contents/MacOS/Pulldown Support
0x14d55000 – 0x14d94fef com.apple.FinalCutPro.Plugins.QTM Reader 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QTM Reader.bundle/Contents/MacOS/QTM Reader
0x14da1000 – 0x14da9ff3 com.apple.FinalCutPro.Plugins.QuickView 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/QuickView.bundle/Contents/MacOS/QuickView
0x14dae000 – 0x14dbeffe com.apple.FinalCutPro.Plugins.Relink Media 7.0.3 (7.0.3) <67805834-C6B2-061D-7581-E3D7835DB779> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Relink Media.bundle/Contents/MacOS/Relink Media
0x14dc5000 – 0x14e5eff2 com.apple.FinalCutPro.Plugins.Timeline Editor 7.0.3 (7.0.3) <1870750B-B6C6-9132-E680-CA9338AE23D6> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Timeline Editor.bundle/Contents/MacOS/Timeline Editor
0x14e6d000 – 0x14e7efff com.apple.FinalCutPro.Plugins.Transcoder 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transcoder.bundle/Contents/MacOS/Transcoder
0x14e88000 – 0x14e9afff com.apple.FinalCutPro.Plugins.Transition Viewer 7.0.3 (7.0.3) /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Transition Viewer.bundle/Contents/MacOS/Transition Viewer
0x14ea0000 – 0x14eb5ff3 com.apple.FinalCutPro.Plugins.Trimming 7.0.3 (7.0.3) <449089A2-91B0-4CC7-2A2C-0DD44827F041> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Trimming.bundle/Contents/MacOS/Trimming
0x14ebb000 – 0x14ec1ffb com.apple.FinalCutPro.Plugins.VDUSupport 7.0.3 (7.0.3) <33F34BB0-DEBD-B056-BB0F-1F419E20E990> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VDUSupport.bundle/Contents/MacOS/VDUSupport
0x14ec7000 – 0x14ec8ffb com.apple.FinalCutPro.Plugins.Vector Accelerator 7.0.3 (7.0.3) <6FC3291F-5227-348F-8994-EA598417AAEA> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/Vector Accelerator.bundle/Contents/MacOS/Vector Accelerator
0x14ecd000 – 0x14edefff com.apple.FinalCutPro.Plugins.VideoLog 7.0.3 (7.0.3) <1700D722-D1CB-90C0-8248-FD0FD5DD1EC6> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VideoLog.bundle/Contents/MacOS/VideoLog
0x14ee3000 – 0x14efbff7 com.apple.FinalCutPro.Plugins.VoiceOver 7.0.3 (7.0.3) <049BB860-4BA1-7AAB-3836-973493389CF0> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/VoiceOver.bundle/Contents/MacOS/VoiceOver
0x14f02000 – 0x14f7ffe1 com.apple.FinalCutPro.Plugins.XML Support 7.0.3 (7.0.3) <09E858FB-A896-3DF9-46DB-751E6884D820> /Applications/Final Cut Pro.app/Contents/MacOS/Plugins/XML Support.bundle/Contents/MacOS/XML Support
0x153e8000 – 0x153e9ff7 com.apple.Helium 3.0.3 (359) <1B909921-EE16-B317-3670-B0C63C70F01B> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Helium
0x153f9000 – 0x153fafff com.apple.FxHeliumImage 4.0.0 (1.0) <62A25655-AB02-73F7-FE2B-21823D2D4BA4> /Library/Application Support/ProApps/SharedA/Frameworks/FxHeliumImage.framework/Versions/A/FxHeliumImage
0x15825000 – 0x15827ff3 com.apple.LiveType.component 2.1.4 (2.1.4) /Library/QuickTime/LiveType.component/Contents/MacOS/LiveType
0x1582d000 – 0x15891fe2 com.apple.LiveType.framework 2.1.4 (2.1.4) /Library/Application Support/ProApps/SharedA/Frameworks/LiveType.framework/Versions/A/LiveType
0x158b1000 – 0x158f7ffb com.apple.motion.component 1.0 (729) <494487C6-EA30-43DD-39E4-BED23C5A5B1C> /Library/QuickTime/Motion.component/Contents/MacOS/Motion
0x158fd000 – 0x158ffff7 Motion 729.0.0 (compatibility 1.0.0) <051B60E9-B39F-EBB2-5B96-F088D147E78C> /Library/Frameworks/Motion.framework/Versions/A/Motion
0x15905000 – 0x159a2ff8 com.apple.procore.framework 4.0.2 (757) /Library/Application Support/ProApps/SharedA/Frameworks/ProCore.framework/Versions/A/ProCore
0x159e2000 – 0x159f6fef com.apple.fcp.DVOutputUnit 1.3 (1.3) <691D07F3-84FB-39BE-AB16-213751718437> /Applications/Final Cut Pro.app/Contents/Resources/DVOutputUnit.bundle/Contents/MacOS/DVOutputUnit
0x15ca6000 – 0x15cc7ff3 +com.aja.kona.codec 8.0 (8.0) /Library/QuickTime/AJACodec.component/Contents/MacOS/AJACodec
0x15cd7000 – 0x15ce8fe7 com.apple.FCP Uncompressed 422.component 1.6.1 (1.6.1) <62C290FB-2735-60C4-CE88-7ECB0DE6EDB3> /Library/QuickTime/FCP Uncompressed 422.component/Contents/MacOS/FCP Uncompressed 422
0x15cef000 – 0x15d5cfe7 com.apple.AppleProResCodec 2.0 (224) /Library/QuickTime/AppleProResCodec.component/Contents/MacOS/AppleProResCodec
0x15da9000 – 0x1618efe3 QuickTimeH264.scalar ??? (???) <535C2E62-CDFC-4B97-B7B0-8B21D724F1C9> /System/Library/QuickTime/QuickTimeH264.component/Contents/Resources/QuickTimeH264.scalar
0x161ea000 – 0x16221fe7 com.apple.DVCPROHDCodec 1.5 (237) <5BA42205-5AEE-73BB-A7DE-5417EF028D5B> /Library/QuickTime/DVCPROHDCodec.component/Contents/MacOS/DVCPROHDCodec
0x16231000 – 0x162e0fe3 com.apple.AppleHDVCodec 1.6 (229) /Library/QuickTime/AppleHDVCodec.component/Contents/MacOS/AppleHDVCodec
0x16308000 – 0x16322ffb com.apple.AppleIntermediateCodec 1.3.1 (152) <1B307E03-0CE7-C8E0-7400-84952993C66C> /Library/QuickTime/AppleIntermediateCodec.component/Contents/MacOS/AppleIntermediateCodec
0x16328000 – 0x1633bfe3 com.apple.IMXCodec 1.4 (155) /Library/QuickTime/IMXCodec.component/Contents/MacOS/IMXCodec
0x1634d000 – 0x16366fe7 com.apple.applepixletvideo 1.2.19 (1.2d19) <4A68731C-8071-6CF5-012C-40F00CD1333A> /System/Library/QuickTime/ApplePixletVideo.component/Contents/MacOS/ApplePixletVideo
0x1636b000 – 0x163a7fe3 com.apple.QuickTimeFireWireDV.component 7.6.6 (1756) <5723A7A8-2C99-561B-8D87-C8B0716436FA> /System/Library/QuickTime/QuickTimeFireWireDV.component/Contents/MacOS/QuickTimeFireWireDV
0x1650c000 – 0x16510ff3 com.apple.SmoothCamFxPlug 1.0.1 (1.0.1) /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/SmoothCam.fxplug/Contents/MacOS/SmoothCam
0x16517000 – 0x16517ffc com.apple.qmaster.swamp 3.5.3 (3.5.3) <7766A14C-1FFD-C0FD-5BB3-5269DE4C4CF7> /Library/Frameworks/Qmaster.framework/Versions/A/Qmaster
0x1651b000 – 0x16553fff com.apple.motion.MotionBundle 4.0.2 (729) <993F121D-D2DE-C81D-B38C-692283E9A29A> /Library/Application Support/ProApps/Bundles/Motion.bundle/Contents/MacOS/Motion
0x1668f000 – 0x16691fff com.apple.Helium.HCache 2.1.0 (359) <669FD4C8-B9A0-549E-EC32-C49718676C34> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Plug-ins/HCache.bundle/Contents/MacOS/HCache
0x166d9000 – 0x166ddff7 com.apple.qldisplay.Generic 2.3 (327.6) /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/Versions/A/Resources/DisplayBundles/Generic.qldisplay/Contents/MacOS/Generic
0x167f0000 – 0x167f8ff7 com.apple.QuartzComposer.QCMotionPatch 1.0 (729) <104A0B24-6D0D-DEEA-6543-753BB407D16A> /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/QCMotionPatch.plugin/Contents/MacOS/QCMotionPatch
0x16900000 – 0x169feff7 com.apple.soundtrackpro.integration 3.0 (3.0) /Library/Application Support/ProApps/Bundles/Soundtrack Pro Integration.bundle/Contents/MacOS/Soundtrack Pro Integration
0x16a60000 – 0x16a6fff7 com.apple.QuartzComposer.FxPlugWrapper 1.2.3 (92) /Library/Application Support/ProApps/SharedA/Plug-Ins/ProFX/FxPlugWrapper.plugin/Contents/MacOS/FxPlugWrapper
0x16a7a000 – 0x16a86fff com.apple.PluginManager 1.7.3 (34) <13CD3A05-A00C-4FA7-AD61-2A706A67E390> /Library/Frameworks/PluginManager.framework/Versions/B/PluginManager
0x16a93000 – 0x16aa4ff7 com.apple.fxplugframework 1.2.3 (1.2.3) <033FEA79-E666-D319-5BD5-25A9A4331190> /Library/Frameworks/FxPlug.framework/Versions/A/FxPlug
0x16ad1000 – 0x16aeafff com.apple.promath.framework 4.0.2 (729) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMath.framework/Versions/A/ProMath
0x16c00000 – 0x16c33ff7 +com.aja.kona.videooutputcodec 8.0 (8.0) <6B81FD68-2E8F-E3E5-391E-0245796B7C1E> /Library/QuickTime/AJAVideoOutputCodec.component/Contents/MacOS/AJAVideoOutputCodec
0x16c4d000 – 0x16c51ff3 com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/Contents/MacOS/AudioIPCPlugIn
0x16c56000 – 0x16c5cffb com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Contents/MacOS/AppleHDAHALPlugIn
0x16c61000 – 0x16c6cff0 com.apple.fcp.TundraOutputUnit 1.3.1 (1.3.1) <71D84D8B-50CF-D900-8558-EDEA70827C8F> /Applications/Final Cut Pro.app/Contents/Resources/TundraOutputUnit.bundle/Contents/MacOS/TundraOutputUnit
0x16c75000 – 0x16c80ff7 com.apple.DVCPROHDVideoOutput 1.3.2 (1.3.2) <738D36A7-8DBD-3BD7-CD35-4B171397782C> /Library/QuickTime/DVCPROHDVideoOutput.component/Contents/MacOS/DVCPROHDVideoOutput
0x16c88000 – 0x16cedfe0 com.apple.DVCPROHDMuxer 1.3.2 (1.3.2) /Library/QuickTime/DVCPROHDMuxer.component/Contents/MacOS/DVCPROHDMuxer
0x16d07000 – 0x16d09ff3 +com.aja.kona.videooutputclock 8.0 (8.0) /Library/QuickTime/AJAVideoOutputClock.component/Contents/MacOS/AJAVideoOutputClock
0x16d0d000 – 0x16d19fff com.apple.FinalCutPro.iChatTheaterPreview 1.0 (195) /Library/QuickTime/iChatTheaterPreview.component/Contents/MacOS/iChatTheaterPreview
0x16d2c000 – 0x16d43fe7 libedit.2.dylib 2.11.0 (compatibility 2.0.0) <45688CB7-9BE4-5D1B-C209-A414EE98C5D2> /usr/lib/libedit.2.dylib
0x16d50000 – 0x16d61fff com.apple.RetimingMath 4.0.2 (729) <2ED17500-06D7-08B5-441F-AFE5DDDE71AD> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/RetimingMath.framework/Versions/A/RetimingMath
0x16d96000 – 0x16d9bffb com.apple.fxmetaplug.ImageUnit 1.2.2 (1.2.2) <874EE8A7-B644-32C8-D8E2-1E4EA379C31B> /Library/Application Support/ProApps/Internal Plug-Ins/FxMetaPlug/ImageUnit.fxmetaplug/Contents/MacOS/ImageUnit
0x17127000 – 0x1785cfdf +com.borisfx.TextScrambler ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Text Scrambler.bundle/Contents/MacOS/Text Scrambler
0x1829b000 – 0x183edfec com.apple.Helium.HeliumRender 2.0.3 (359) <93D90702-A8F2-B483-818A-6C5E85D7000F> /Library/Application Support/ProApps/SharedA/Frameworks/Helium.framework/Versions/A/Frameworks/HeliumRender.framework/Versions/A/HeliumRender
0x18446000 – 0x1847cffa com.apple.proinspector.framework 4.0.2 (761) /Library/Application Support/ProApps/SharedA/Frameworks/ProInspector.framework/Versions/A/ProInspector
0x1865d000 – 0x186a8ff4 com.apple.Bloodhound 4.0.2 (729) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Bloodhound.framework/Versions/A/Bloodhound
0x186d3000 – 0x186e5fff com.apple.motion.Text 4.0.2 (729) <21A95797-1AC2-730A-8063-57A923D7F70A> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Text.ozp/Contents/MacOS/Text
0x186f2000 – 0x186f7fe7 com.apple.H264Encoder 1.0 (21) /Library/Application Support/ProApps/SharedA/Frameworks/H264Encoder.framework/Versions/A/H264Encoder
0x18800000 – 0x18f32fc7 +com.borisfx.Title3D ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title 3D.bundle/Contents/MacOS/Title 3D
0x19970000 – 0x199b1fe3 com.apple.audio.SoundManager.Components 3.9.4 (3.9.4) /System/Library/Components/SoundManagerComponents.component/Contents/MacOS/SoundManagerComponents
0x199b8000 – 0x199c2ff7 com.apple.IOFWDVComponents 1.9.9 (1.9.9) <5B4E7BD7-EF5A-2F5C-DF8E-3D4A7B59F779> /System/Library/Components/IOFWDVComponents.component/Contents/MacOS/IOFWDVComponents
0x199cc000 – 0x199d6ff7 com.apple.compressor.MediaServerAPI 3.5.3 (3.5.3) /Library/Frameworks/MediaServerAPI.framework/Versions/A/MediaServerAPI
0x199e3000 – 0x199eefff com.apple.compressor.StompUtil 3.5.3 (3.5.3) <7589A431-23FA-B445-A452-7E3E99DF531B> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUtil.framework/Versions/A/StompUtil
0x19b00000 – 0x1a230fef +com.borisfx.TitleCrawl ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Title Crawl.bundle/Contents/MacOS/Title Crawl
0x1ac6d000 – 0x1b3a3ff7 +com.borisfx.VectorShape ??? (2.1) /Library/Application Support/Final Cut Pro System Support/Plugins/Vector Shape.bundle/Contents/MacOS/Vector Shape
0x1bdee000 – 0x1bdf4fff com.apple.compressor.FilterUI 3.5.3 (3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/FilterUI.framework/Versions/A/FilterUI
0x1bf00000 – 0x1c16afe2 com.apple.motion.filters 4.0.2 (604) <43E12D87-F63D-496D-3143-61C198C179BD> /Library/Application Support/ProApps/SharedA/Plug-Ins/FxPlug/Filters.bundle/Contents/MacOS/Filters
0x1c223000 – 0x1c2e0fe2 com.apple.DesktopVideoOut 1.2.7 (1.2.7) <54E0C747-1169-FB4A-2CB4-9EA9BD5398F8> /Library/QuickTime/DesktopVideoOut.component/Contents/MacOS/DesktopVideoOut
0x1c2ff000 – 0x1c345fe3 +com.aja.kona.videooutput 8.0 (8.0) /Library/QuickTime/AJAVideoOutput.component/Contents/MacOS/AJAVideoOutput
0x1c363000 – 0x1c39bff7 com.apple.CompressorKit 3.5.3 (3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/CompressorKit.framework/CompressorKit
0x1c3ca000 – 0x1c3d5fff com.apple.qmaster.SwampUtil 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUtil.framework/Versions/A/SwampUtil
0x1c3e2000 – 0x1c3ebfff com.apple.qmaster.SwampService 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampService.framework/Versions/A/SwampService
0x1c600000 – 0x1cee1fe2 com.apple.ozone.framework 4.0.3 (729) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/Ozone.framework/Ozone
0x1d383000 – 0x1d456fff org.python.python 2.5.4 (2.5) <2425B12D-D1AB-C0EE-D6EF-64D5600F6905> /System/Library/Frameworks/Python.framework/Versions/2.5/Python
0x1d496000 – 0x1d5feff2 com.apple.ProMedia 4.0.2 (729) <07F6C2C0-ACFD-27D8-D887-74E47F0196F9> /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProMedia.framework/Versions/A/ProMedia
0x1d66f000 – 0x1d6d9ff2 com.apple.ProGraphics 4.0.3 (729) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/ProGraphics.framework/Versions/A/ProGraphics
0x1d7f6000 – 0x1d97afe2 com.apple.Lithium 4.0.2 (729) <228EB85A-BDBC-55EE-9AC6-E4990DB34DFF> /Library/Application Support/ProApps/SharedA/Frameworks/Lithium.framework/Versions/A/Lithium
0x1da01000 – 0x1dacfff3 com.apple.prochannel.framework 4.0.2 (763) <721D6E76-2081-097D-4C2E-22C6162B8DDB> /Library/Application Support/ProApps/SharedA/Frameworks/ProChannel.framework/Versions/A/ProChannel
0x1db6e000 – 0x1df22ff2 com.apple.motion.TextFramework 4.0.2 (729) /Library/Application Support/ProApps/SharedA/Frameworks/Motion/TextFramework.framework/TextFramework
0x1dfdf000 – 0x1e176ff8 com.apple.motion.Behaviors 4.0.2 (729) <052F3433-97BD-1C55-C23D-AD92143C71F8> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Behaviors.ozp/Contents/MacOS/Behaviors
0x1e215000 – 0x1e3b2ff8 com.apple.motion.Particles 4.0.2 (729) <049BF10B-9B06-52CF-E500-79AE1AB90ED4> /Library/Application Support/ProApps/SharedA/Plug-Ins/Motion/Particles.ozp/Contents/MacOS/Particles
0x1e40e000 – 0x1e48bffb +com.aja.kona.muxer 8.0 (8.0) <1BB8E116-7B24-E9C5-50AB-FE60B434E0FC> /Library/QuickTime/AJAMuxer.component/Contents/MacOS/AJAMuxer
0x1e501000 – 0x1e65bff7 com.apple.AECore 3.5.3 (3.5.3) <2BAD733C-D2F3-F9FD-C5CD-22C23820EE15> /Library/Frameworks/AECore.framework/Versions/A/AECore
0x1e6f3000 – 0x1e795fef com.apple.compressor.StompUI 3.5.3 (3.5.3) <6E15FAA4-A6BA-3DCD-0607-5ECBDDE1439D> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompUI.framework/Versions/A/StompUI
0x1e7f3000 – 0x1e8dcfe3 com.apple.compressor.StompTypes 3.5.3 (3.5.3) <8ACF288B-C692-9A76-182F-1327BF365470> /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/StompTypes.framework/Versions/A/StompTypes
0x1e965000 – 0x1e999fff com.apple.qmaster.SwampCore 3.5.3 (3.5.3) <173511EA-C5F3-D58C-3A56-A99C3BED8506> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampCore.framework/Versions/A/SwampCore
0x1e9c4000 – 0x1ea8dfe3 com.apple.qmaster.SwampTypes 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampTypes.framework/Versions/A/SwampTypes
0x1eb1b000 – 0x1eb8fff8 com.apple.qmaster.do 3.5.3 (3.5.3) <4CE7B752-D141-5B9D-6248-8A6A6E0240F9> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/DistributedObjects.framework/Versions/A/DistributedObjects
0x1ebf8000 – 0x1ec02fff com.apple.qmaster.Status 3.5.3 (3.5.3) <750051BA-26B7-52BD-0636-F2F1F3DB9EED> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/Status.framework/Versions/A/Status
0x1ec17000 – 0x1ec22fff com.apple.qmaster.RequestProcessing 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/RequestProcessing.framework/Versions/A/RequestProcessing
0x1ec36000 – 0x1ec49ffb com.apple.qmaster.ServiceControl 3.5.3 (3.5.3) <01DD590C-6953-D428-FEFC-A59CDAD53349> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ServiceControl.framework/Versions/A/ServiceControl
0x1ec62000 – 0x1eccfff7 com.apple.qmaster.ContentControl 3.5.3 (3.5.3) <79754868-87EA-467B-D09C-C4579E6F2E6E> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ContentControl.framework/Versions/A/ContentControl
0x1ed17000 – 0x1ed22fff com.apple.qmaster.ClusterManager 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/ClusterManager.framework/Versions/A/ClusterManager
0x1ed31000 – 0x1ed5bff7 com.apple.qmaster.SwampUI 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampUI.framework/Versions/A/SwampUI
0x1ed80000 – 0x1ed8bfff com.apple.qmaster.SwampExecutor 3.5.3 (3.5.3) <85C50FA9-CDBD-B8FD-D271-1B7275A7CF49> /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/SwampExecutor.framework/Versions/A/SwampExecutor
0x1ed9f000 – 0x1edabfff com.apple.dsppublishing 1.0.1 (119) <2C4E2A5C-6E41-2CD9-533B-36145D1C7987> /Library/Frameworks/DSPPublishing.framework/Versions/A/DSPPublishing
0x1edbc000 – 0x1ede5fe3 com.apple.audio.CoreAudioKit 1.6.1 (1.6.1) <7FFBD485-5251-776A-CC44-4470DD84112B> /System/Library/Frameworks/CoreAudioKit.framework/Versions/A/CoreAudioKit
0x3145a000 – 0x3151ffff com.apple.qmaster.JobControl 3.5.3 (3.5.3) /Library/Frameworks/Qmaster.framework/Versions/A/Frameworks/JobControl.framework/Versions/A/JobControl
0x315a8000 – 0x315e0fff com.apple.compressor.ImageProcessing 3.5.3 (3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/ImageProcessing.framework/Versions/A/ImageProcessing
0x31609000 – 0x317a9ffb com.apple.compressor.transcoding 3.5.3 (3.5.3) /Library/Frameworks/Compressor.framework/Versions/A/Frameworks/Transcoding.framework/Versions/A/Transcoding
0x31946000 – 0x3194bff1 com.apple.finalcutpro.dvcprohdfrcplugin 1.2.0 (16) /Applications/Final Cut Pro.app/Contents/PlugIns/DVCPROHD Frame Rate Converter.bundle/Contents/MacOS/DVCPROHD Frame Rate Converter
0x4bebf000 – 0x4bee3ff7 com.apple.AppleAVCIntraCodec 1.0 (16) <8A1A4CEE-1610-EECE-74DA-D2AF42825E6D> /Library/QuickTime/AppleAVCIntraCodec.component/Contents/MacOS/AppleAVCIntraCodec
0x522ee000 – 0x52368fe7 com.apple.AppleVAH264HW.component 2.0 (1.0) /System/Library/QuickTime/AppleVAH264HW.component/Contents/MacOS/AppleVAH264HW
0x70000000 – 0x700cbff3 com.apple.audio.units.Components 1.6.3 (1.6.3) <5DA35A22-1B05-6BD3-985A-26A7A2CD6289> /System/Library/Components/CoreAudio.component/Contents/MacOS/CoreAudio
0x8f0c8000 – 0x8f811ff7 com.apple.GeForceGLDriver 1.6.24 (6.2.4) /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
0x8fe00000 – 0x8fe4162b dyld 132.1 (???) /usr/lib/dyld
0x90003000 – 0x9000aff3 com.apple.print.framework.Print 6.1 (237.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Versions/A/Print
0x9001e000 – 0x9006fff7 com.apple.HIServices 1.8.1 (???) <51BDD848-32A5-2425-BE07-BD037A89630A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices.framework/Versions/A/HIServices
0x90075000 – 0x90177fef com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.framework/Versions/A/MeshKitIO
0x90182000 – 0x90186ff7 libGIF.dylib ??? (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
0x90187000 – 0x90209ffb SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
0x9020a000 – 0x9023dff7 com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Versions/A/AE
0x9023e000 – 0x90260fef com.apple.DirectoryService.Framework 3.6 (621.9) /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
0x90261000 – 0x90390fe3 com.apple.audio.toolbox.AudioToolbox 1.6.5 (1.6.5) <0A0F68E5-4806-DB51-764B-D97554B801AD> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
0x90391000 – 0x903defeb com.apple.DirectoryService.PasswordServerFramework 6.0 (6.0) /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
0x903df000 – 0x90411fe3 libTrueTypeScaler.dylib ??? (???) <6E9D1A50-330E-F1F4-F93D-9ECC8A61B21A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/Resources/libTrueTypeScaler.dylib
0x90412000 – 0x9041dff7 libCSync.A.dylib 545.0.0 (compatibility 64.0.0) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphics.framework/Versions/A/Resources/libCSync.A.dylib
0x90437000 – 0x90437ff7 com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
0x90534000 – 0x90549fff com.apple.ImageCapture 6.0.1 (6.0.1) /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/Versions/A/ImageCapture
0x9054a000 – 0x90a03ffb com.apple.VideoToolbox 0.484.20 (484.20) /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
0x90a04000 – 0x90a4bffb com.apple.CoreMediaIOServices 133.0 (1158) <150A5F22-E7EC-9E8E-3B68-BAD75280EFC3> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOServices
0x90a4f000 – 0x90a56ff7 com.apple.iChat.IMUtils 5.0.5 (747) <165000D5-219A-DFAE-68C6-25F6ED12A00B> /System/Library/Frameworks/IMCore.framework/Frameworks/IMUtils.framework/Versions/A/IMUtils
0x90a57000 – 0x90b32feb com.apple.DesktopServices 1.5.9 (1.5.9) /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopServicesPriv
0x90b33000 – 0x90b40ff7 com.apple.NetFS 3.2.1 (3.2.1) <5E61A00B-FA16-9D99-A064-47BDC5BC9A2B> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
0x90b41000 – 0x90b41ff7 com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
0x90b42000 – 0x90b66ff7 libJPEG.dylib ??? (???) <46AF3A0F-2B8D-87B9-62D4-0905678A64DA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
0x90b67000 – 0x90c17fe3 com.apple.QuickTimeImporters.component 7.6.6 (1756) <9276DEF5-B027-75CD-A0EB-69709F903196> /System/Library/QuickTime/QuickTimeImporters.component/Contents/MacOS/QuickTimeImporters
0x90c18000 – 0x90c48ff7 com.apple.MeshKit 1.1 (49.2) /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
0x90c54000 – 0x90c58ff7 libGFXShared.dylib ??? (???) /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
0x90c59000 – 0x90cbafe7 com.apple.CoreText 3.5.0 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.framework/Versions/A/CoreText
0x90cbb000 – 0x90cbbff7 com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
0x90cbc000 – 0x90ccaff7 com.apple.opengl 1.6.11 (1.6.11) <286D1BC4-4CD8-3CD4-F723-5C196FE15FE0> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
0x90ccb000 – 0x90d0bff3 com.apple.securityinterface 4.0.1 (37214) /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
0x90d0c000 – 0x90da7ff7 com.apple.ApplicationServices.ATS 4.4 (???) /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framework/Versions/A/ATS
0x90f0b000 – 0x90f0eff7 libCoreVMClient.dylib ??? (???) <1F738E81-BB71-32C5-F1E9-C1302F71021C> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCor -
Mike Kahn
January 16, 2011 at 6:50 pmI have put the media onto internal 2TB Striped Raid (2x 1TB internal drives) and most of the crashing has gone away but the playback stutter is still present.
Anyone ever experience anything like this?
