Activity › Forums › Adobe Premiere Pro › Playback issue on transferred 5.5 project
  • Playback issue on transferred 5.5 project
    Posted by Joel Morales on October 4, 2011 at 9:11 pm
    Hello.
    This is my first time posting in the forums. I apologize in advance if it is a “dumb question”. I searched through the forums for a previous posting regarding my issue but could not find one. I will try and be as detailed as possible and if there is a proper etiquette I am failing to follow please let me know.
    Here is the situation.
    The Hardware:
    1) Macbook Pro – 2 GHz Intel Core i7
    2) iMac – 3.4 GHz Intel Core i7
    3) Western Digital 2 TB external hard drive
    4) Panasonic HMC 150 recording on SDHC class 10 in avchd format.
    Software:
    Premiere Pro 5.5
    Situation:
    I work as a videographer for a university and was editing a project in Premiere 5.5 on my own macbook pro. Just recently the computer services dept. installed Premiere Pro 5.5. on my work station here (the iMac). I am saving my project along with all the footage (avchd) on the same external western digital hd.
    When I ejected the hard drive FROM the macbook and plugged it INTO the iMac, I opened the project in Premiere Pro 5.5 on the iMac. The project opened correctly. All the media was there. However, when I press spacebar to play the clip (this is both inside the timeline and the source window) It only plays for a second and then returns back to the first frame I pressedy play.
    STEPS I HAVE TAKEN:
    1)Check the version of both my OS and Premiere Pro 5.5. The versions match across the board.
    2) I tried reconnecting the external hd back to my macbook pro and Premiere acts completely normal and as it should.
    Any help with this issue would be greatly appreciated. Thanks for your time.
    -Joel
    Joel Morales replied 14 years, 11 months ago 4 Members · 8 Replies
  • 8 Replies
  • Kevin Monahan
    October 4, 2011 at 11:21 pm
    [Joel Morales] “3) Western Digital 2 TB external hard drive”
    How is the drive connected to your Mac? FW800, eSATA?
    Kevin Monahan
    Sr. Content and Community Lead
    Adobe After Effects
    Adobe Premiere Pro
    Adobe Systems, Inc.
    Follow Me on Twitter!
  • Jeff Greenberg
    October 5, 2011 at 11:34 am
    I don’t know if this is your problem – but anytime I hear ‘playback stops’ with Premiere Pro – it’s usually fixed by this article (shouldn’t do any real harm if wrong either)
    Best,
    Jeff G
    Apple Master Trainer | Avid Cert. Instructor DS/MC | Adobe Cert. Instructor
    You should follow me (filmgeek) on twitter. I promise to be nice.
    New- my book (with Richard Harrington and Robbie Carman)- An Editor’s Guide to Adobe Premiere Pro
    Compressor Essentials from Lynda.com
    (older but still good) Marquee, Media Composer (3.5) and Basic/Advanced Color DVDs (1.0) from Vasst.com
    Contact me through my Website
  • Joel Morales
    October 5, 2011 at 1:42 pm
    The hard drive is connected via FW800.
  • Joel Morales
    October 5, 2011 at 1:46 pm
    Unfortunately, I searched for that specific file and it wasn’t even present in the folder where it directed me. Thank you so much for the suggestion though!
  • Joel Morales
    October 5, 2011 at 1:53 pm
    Another note.
    Every time I open the project on my iMac it goes through the process of conforming all my .mts files. I have never saved the project and reopened it after it was done conforming for fear of not even having the ability to edit on my macbook pro.
  • Joel Morales
    October 5, 2011 at 1:57 pm
    I just tried saving the project with a different file name (still preserving my old project file) It failed to resolve anything.
  • Todd Kopriva
    October 6, 2011 at 4:20 am
    Try the other solution in the document Jeff linked to: the solution involving logging in as root.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Joel Morales
    October 11, 2011 at 5:12 am
    The root option worked perfectly! Thank you!
